1Back to top Go down   Spectacular Empty Spectacular Mon Dec 16, 2013 12:11 pm
komandoalicante
komandoalicante
Great es el result of exchanging them light bulbs del cuadro
* By that unas buy from Dealextreme.
This es el cuadro before empezar
Spectacular Cimg3166r
the lamps, the original with its cap and without the new
Spectacular Cimg3176
With the cap removed or lamps porta
Spectacular Cimg3177
And with the new lamps porta
Spectacular Cimg3180f
hese are the four lighting
Spectacular Cimg3181t
And these the clock and checkup
Spectacular Cimg3184
And the end result
Spectacular Cimg3187
What do think?
more information
Spectacular Cimg3415
Spectacular Cimg3419t
First, pictures are taken completely dark.
And even if we may seem, we are already several in that match the light from the box does not bother driving, having a clear and quick read.
On the other hand, less proven in the lamps we use the shortest driver was positive, deploy drivers for that as you can see in the picture below. (Drivers eye out for each side)
Spectacular Cimg3416p
and also mark where are the positive and negative to mount in the box.
Spectacular Cimg34181
SAK3 and komandoalicante is the same person
In March we made a International meeting  KEDADA ALICANTE of BMW motorcycle K in  Spain.
The last meeeting  March 2020
https://youtu.be/hfqxlGeEVsY
https://picasaweb.google.com/100417997445250027277
2Back to top Go down   Spectacular Empty Re: Spectacular Mon Dec 16, 2013 1:58 pm
dmanley
dmanley
Very nice.
Daryl
1985 K100RT
3Back to top Go down   Spectacular Empty Re: Spectacular Mon Dec 16, 2013 4:50 pm
They sure are a better light, far more even. Is there a way to dim them for riding in the open road where they may be too bright.
4Back to top Go down   Spectacular Empty Re: Spectacular Mon Dec 16, 2013 10:16 pm
komandoalicante
komandoalicante
hola ricK  T
Puedes construir un circuito electronico que regula la tensión
5Back to top Go down   Spectacular Empty Re: Spectacular Tue Dec 17, 2013 2:16 am
JR_K100RS
JR_K100RS
"you can build an electronic circuit that regulates the voltage"
JR
6Back to top Go down   Spectacular Empty Re: Spectacular Mon Feb 03, 2014 12:15 pm
komandoalicante
komandoalicante
If it could be done in two ways
If the bulbs are normanes would have to regulate voltage.
If the bulbs are LED pulses would have to give.
Similar topics
» Spectacular
