1Back to top Go down   Where does flat braided cable go? Empty Where does flat braided cable go? Thu Sep 05, 2013 12:02 am
Dale S
Dale S
I was doing some cleaning under the instrument panel and found a
stainless flat braided cable wraped up with the wires that go down
from the panel under the front of the tank. The end of the cable
has a flat lug connector on it that is not connected to anything.
I carefully unwound the thing (ground strap?) and I had about
12 inches of length to go where? cant seem to find it in any wiring
diagrams. Everything elecrical works fine! My LT had a radio originally
but has been removed by PO.  The cable reaches the left side compartment but It seems too heavy-duty to be for a radio.
It doesnt look like a modification or anything. Where does it go?
Anybody Know?
2Back to top Go down   Where does flat braided cable go? Empty Re: Where does flat braided cable go? Thu Sep 05, 2013 12:40 am
It goes in the bin.
Unless you have a very large slot car.
Part of an overly zealous earthing program generally facilitated by a local policing authority.
They can be found attched to petrol tanks, the front forks/ steering head and under tank earth point, from one side of the crash bar mounting bolt to the frame and any number of other places the authorities thought may be a source of poor earthing.
Where does flat braided cable go? Dsc_0010
Where does flat braided cable go? Dsc_0011
And finally here
Where does flat braided cable go? Dsc_0012
Last edited by rossko on Thu Sep 05, 2013 12:47 am; edited 1 time in total (Reason for editing : photos)
3Back to top Go down   Where does flat braided cable go? Empty ground strap Thu Sep 05, 2013 12:47 am
Dale S
Dale S
Hmmm,  I do have some old scalectrix in the attic!Cool
Nice pics! Yep thats what I needed
Thanks Rossko!Very Happy
Last edited by Dale S on Thu Sep 05, 2013 12:57 am; edited 1 time in total (Reason for editing : spelling)
From what I gathered it was used mainly on the tank to frame because the Police bikes were getting RF interference from the electric motor on the fuel pump so unless you are using a VHF Radio then it serves no piont so as for RossKos advice carefully follow it and all will be well.
5Back to top Go down   Where does flat braided cable go? Empty Where does flat braided cable go? Thu Sep 05, 2013 1:54 am
Dale S
Dale S
Come to think of it, the PO did mention something about the OO
being a policeman. Must have had a VHF on his private ride
 Idea
6Back to top Go down   Where does flat braided cable go? Empty Re: Where does flat braided cable go? Thu Sep 05, 2013 11:28 am
Ghost who rides
Ghost who rides
WOW you nailed that one RossKKo or sledgehammered it more like!
Are you the forum expert on Police rf Shielding?
Ghost who rides wrote:WOW you nailed that one RossKKo or sledgehammered it more like!
Not really. I had the same head scratching moment as Dale.
8Back to top Go down   Where does flat braided cable go? Empty Where does flat braided cable go? Thu Sep 05, 2013 11:02 pm
Dale S
Dale S
Problem solved.
I took it off & used it to ground the starter motor in my old Ford truck!Rolling Eyes
9Back to top Go down   Where does flat braided cable go? Empty Re: Where does flat braided cable go? Thu Sep 05, 2013 11:39 pm
Congratulations they aren't useless after all, jolly good work.Very Happy
10Back to top Go down   Where does flat braided cable go? Empty Re: Where does flat braided cable go? Fri Sep 06, 2013 6:56 pm
klamityboy
klamityboy
As a side note on Police spec equipment, when I priced out a replacement fuel pump from the dealer the "police" model was CDN$850 (supposedly RF shielded), regular was CDN $550. Purchased one from Euromotoelecrics for US$229. Wonder if the alternator I just replaced had a police variant for 4X the cost?
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
