1 engine cuts out sometimes, won't start sometimes, intermittent and unpredictable Sat Oct 15, 2011 3:14 am
dennisg844
Help! I'm posting in electric because the problem seems like an electric one. The topic just about says it all. '85 K100RT (stripped of the fairing). Engine will cut out while running, for just a split second, occasionally, not very often at all and usually does not happen on a run. Engine will run perfectly and then not start, sometimes. This might happen when the engine is hot or cold. Console lights come on and are bright when I turn the key. Headlight is on and bright. When it happens, I wait and it starts up and runs perfectly. One time, I left it where it was, went home and came back the next morning and it started. The other time, today, I waited just a few minutes and it started and ran superbly after trying several times to start it. But, while it was idling, it died like somebody turned off a switch, but started right up again.
I hesitate to mention it because I believe it is just a coincidence, but, today, I shifted into first, clutch pulled in, to try starting it and it started. This was after trying to start it in neural.
The kill switch assembly has recently been replaced as it was causing "stopping" problems.
The ignition switch has also recently been replaced.
Spark plugs changed about 1000 miles ago.
Fuel filer replaced at same time as spark plugs.
Fuel tank emptied and cleaned.
When engine cuts out, it's like a switch is turned off, no sputtering, etc.
One time when it would not start, I pulled the fuel line to the injector rail and cranked the starter; fuel pumped out. Still would not start.
I thought maybe there's a short somewhere but wouldn't that be a consistent problem, at least when I am sitting there, waiting to try starting the engine again?
When it happened one time and then started, a friend put a spark tester on the wires above the injector rail and said #1 was running erratically. It was idling kind of rough at that time. He was thinking maybe the wiring harness there (at least the wire to #1) was bad. Would that cause the engine to quit, or not start?
I really appreciate any advice and/or guesses about this.
I'm having hip replacement surgery in a couple of days and won't be able to ride for awhile so solving this problem will keep me busy until I can get back on the bike.
Thanks to all,
Dennis
Thanks to all,
Dennis
