1Back to top Go down   Seattle K-Biker Empty Seattle K-Biker Fri Aug 19, 2011 6:13 pm
91k100rs
Greetings! I just got my first bike - its a '91 K100RS 4-valve with 50K miles. I just returned from a 3000 mile trip - me and the bike made it!
On the second to last day of the trip something happened with the bike - it developed an oil leak and its making a knocking noise at idle. It rides just fine out on the highway - power and fuel economy are unchanged. It didn't loose much oil - I kept a close eye on it. Temps normal. The sound changes when the clutch is pulled (with bike in neutral), so I'm hoping it is the throwout bearing (or possible input shaft bearing).
I will be tearing into it in a few weeks... planned to do a spline lube and look at the clutch while I am in there (I did lube the rear splines before the trip). Hoping to get it fixed up quickly so I can ride it some more this summer!
Thanks for reading!
2Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Fri Aug 19, 2011 7:47 pm
Welcome 91k100rs
glad to see another happy camper.
Try and clean the bottom of the crankcase and all around the rubber boot on the clutch arm, then keep your eye out for a location of the leak.
There are experts here who can point you in the right direction once the culprit area is found. I'm not one of them mate but they have helped me a lot.
3Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Fri Aug 19, 2011 9:12 pm
Welcome to the forum
There is a small rubber tube that goes from the plenum chamber which is the air box above the throttle bodies to the crankcase, if that is leaking air into the plenum chamber then the engine will run rough at idle which causes a knocking and it will leak oil down the cases behind the coils. That is the first place to look.
4Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Sat Aug 20, 2011 12:23 am
welcome 91k100rs
5Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Sat Aug 20, 2011 5:26 am
club_c
club_c
Welcome from just north of the 49th. I think you're clue is things change when you disengage the clutch FWIW.
1988 K100RS SE VIN 01477554
6Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Sat Aug 20, 2011 6:19 pm
Hi 91k100rs,
Good to have you on board, hope the problem is an easy fix.
7Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Sun Aug 21, 2011 9:04 am
BIG D
BIG D
Cool
Hi 91K100rs,
welcome to the forum lets see a pic of your pride and joy.
BIG D
8Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Sun Aug 21, 2011 2:21 pm
g35corona
g35corona
Welcome from the other side of the continent.
Bob
;BMW;
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
9Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Fri Aug 26, 2011 8:15 pm
purkolator
Heya,
I'm a new forum member from the Seattle area as well! Woot!
Brad
10Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Fri Aug 26, 2011 8:17 pm
hiya brad ....welcome aboard
11Back to top Go down   Seattle K-Biker Empty Re: Seattle K-Biker Sat Aug 27, 2011 12:36 am
Oldgoat
Oldgoat
Welcome to the board! All these new PNW folks we're going to have to do a ride!?
OG
