1Back to top Go down   Removing fuel injector plugs Empty Removing fuel injector plugs Fri Aug 05, 2011 5:33 pm
chronostorm
Hey guys. So, I've removed 2 of the fuel injector plugs (electrical socket, right?), but I'm having issues getting the other two out.
To be honest, I just yanked on the first two, but I can't get the other two out the same way. Is there some kind of trick to getting these plugs out, or do I just need to pull harder?
Thanks!
2Back to top Go down   Removing fuel injector plugs Empty Re: Removing fuel injector plugs Fri Aug 05, 2011 6:21 pm
There is a small stainless wire clip you will need to remove it using a small screwdriver or a scribe with fine point.
If the other two came off easily check to see they have the clip as it prevents them comming adrift accidentally.
3Back to top Go down   Removing fuel injector plugs Empty Re: Removing fuel injector plugs Fri Aug 05, 2011 9:44 pm
Hi Chronostorm on mine the small spring clip needs to be pushed in as you pull it off. That is common for that style of Bosch electrical connector. If you grasp it with your finger and thumb with one of them depressing the spring as you go to pull it off it comes of so easily one is not aware of pushing it down.
