1 Electrical Issues Thu May 05, 2011 8:35 pm
DSCR
Hello to all. I am new here and new to a 1988 K100RS. I got it for a really low price, the engine seems to crank and run fine. In fact, I think it mostly just needs running. It rides well, shifts well and there are not many strange noises. My Intention is to go over the bike, checking for things that I have read about, change all fluids, grease splines, etc. So I am looking for a good list of things to check.
The purpose of this thread is electrical. If I may, I would like to describe the symptoms and ask if there are possibly common problems that contribute to the listed issues.
What works:
The tail and brake lights. Two separate bulbs, right?
The front running light, after bulb installation (not sure I have the correct bulb, but it works)
The left turn signals, front and rear - AFTER actually plugging together the disconnected connectors behind the front left mirror
All the dash lights work
The low position high beam flasher works
What doesnt work
Both turn signals on the right - Installed new bulbs all around
Low and High beam (again, the high beam flash position works), also all bulb leads show continuity so I think the bulb is good. Also tested headlight plug with tester, juice only to flasher.
I have read the threads about the left, headlight switch going bad so I will dismantle and check it. Could there be a common issue for the headlight and right turn signals? Or two separate issues?
Again, I will check the light switch for juice and corrosion. Where do I start with the right signal circuit?
Thanks for all the time y'all take trying to help inexperienced folks, like myself.
Philip
What works:
What doesnt work
Philip
