1Back to top Go down   Engine.Crash Bar Removal Empty Engine.Crash Bar Removal Sun Apr 17, 2011 7:00 am
CanberraDave
CanberraDave
OK folks here is the first dumb question. I started dismantling the girl today (6/89 K100 RT). One crash bar is broken off but the other is fine. Problem is I cannot work out how to get the crash bar off the good side so I can remove the lower fairing. Not listed in the workshop manual either. I tried unscrewing the broken stub of the other side to see what happens but it appears to be undoing the whole thing rather than just the part that held the crash bar.
Do I need to take the rubber cap off the outer end of the crash bar? If so how do I get it off? Had a go on the crash bar that is broken off but could not work it out.
All help appreciated. Simple words are good short ones are better!!!!!
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
What happens if you get scared half to death twice?
2Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Sun Apr 17, 2011 8:17 am
ill be watching this too ...as i want to install some crash bars one day ...(after i find some with out some rediculous price attached )
but looking at some pics ...i think there is a rubber cap that hides a nut in the tube at the top bar mount ...i guess a long extension will get a socket in there to undo it .....i still have the mounts for crashbars on mine ....and it looks like an 8mm thread ....so im gussing maybe a 16 or 17mm socket would be fitting in there ....at a guess...
that nut mounts to another bolt/nut type adaptor that screws into the engine mount outer (19 mm i think from memory) ......the bolt through the frame has a nut at the back of it....
i think the bottom mounts present themselves without too much hassle dave .
maybe someone else has them fitted as well ? and knows the routine ?
3Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Sun Apr 17, 2011 8:25 am
Under the top plastic endcap there's a nut with 8mm internal threads, so a 13mm socket will/should remove it, then there's a rubber centred stud with threads on either end. This might spin as you attempt to loosen it. An air impact socket, long breaker bar or quick action on your part might help spin it of.
4Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Sun Apr 17, 2011 1:53 pm
BIG D
BIG D
Cool
As TWB stated The end cap has to come off, I recently had to change two top rubber bushings and found that once a 13MM socket has removed the nut in the tubing [I used 3/8 drive for access] and the rest of the tube was removed a socket [if I remember 22 - 24mm]a long extension and a breaker bar did the job, one end of the rubber bushing has a longer thread than the other, longest goes through the tube.
BIG D
5Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Mon Apr 18, 2011 6:03 am
CanberraDave
CanberraDave
Thanks for the advice guys. Bar is off and the lower LH fairing will be next. I noticed a lot of missing chrome that was not evident when it was on the bike. Both bars are pretty solid though so will look at a re-chrome later on.
Do you need to take off the radiator cover before the side panel?
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
6Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Mon Apr 18, 2011 7:10 am
You don't have to take off the radiator cover but you have to remove the 2 screws holding it to the side panel.
I just found a picture of the crashbar mounting but it's a bit late....
Engine.Crash Bar Removal Img0020a
Engine.Crash Bar Removal Img0019csj
Engine.Crash Bar Removal Frog15Engine.Crash Bar Removal Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
7Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Mon Apr 18, 2011 12:03 pm
Chris H
Chris H
Hey Crazy Frog,
In picture 1 I see a rubber grommet on the fairing for the crash bar pass through. Did you add that or am I missing it on the fiche? If you added it, what did you use?
Chris
8Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Mon Apr 18, 2011 12:21 pm
ah !!! looks like a bit of tube that has been split chris .....if you look close you can see the ends nearly touching ...near the bottom
nice idea though bert ...thanks for the images
9Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Mon Apr 18, 2011 12:47 pm
This is not my bike but the one of Crazy Frog #2 (My twin brother)
Here is a place where you can find gromets: http://www.midatlanticrubber.com/grommets.htm
Bert
10Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Mon Apr 18, 2011 1:54 pm
BIG D
BIG D
Cool
Certainly looks better for the grommet Bert, but of course am I not correct in saying you have modified yours by removing the lower piece
under the crash bar for ease of fairing removal.
BIG D
11Back to top Go down   Engine.Crash Bar Removal Empty Re: Engine.Crash Bar Removal Mon Apr 18, 2011 4:32 pm
Even with the cut, a piece of rubber would look better. On of these days I will do it.
Bert
