1Back to top Go down   Dealing with the engine heat Empty Dealing with the engine heat Tue Apr 12, 2011 10:52 pm
Puccini
Anyone have any tips or tricks to deal with the heat from the engine?
It's tolerable except on really hot days.
Also any tips on cleaning the aluminum parts that have gotten mottled?
2Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 3:54 am
This has been discussed first check that all of the insulation bits around the engine are in place often bits can be missing! Then go through and seal them better to the engine and fairing to force the air to vent through the fairing vents.
3Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 7:45 am
Puccini
Can you tell me where I can find the posts for this issue?
Gerry
4Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 6:30 pm
Comberjohn
Comberjohn
Which aluminium bits are mottled?
Has your fairing still got the rubber in-fills around the forks? They can be removed to allow more air to flow through in hot weather.
5Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 6:46 pm
Puccini
The area around the forks is open.
It's my first RT. I had a standard K100 with a bar mounted BMW fairing
before this one.
Is there something that fits in that fork area?
Also the aluminum alloy on the engine and drive areas has that
mild corrosion look.
Not bad but need to be cleaned.
I believe this bike lived in Florida and got some salt air on it.
Good running bike 18K miles.
I just want to get the cosmetics better.
6Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 6:49 pm
The answer about heat management is coming. Just be patient and wait for Robmack reply.
Very Happy
Dealing with the engine heat Frog15Dealing with the engine heat Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
7Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 7:05 pm
soapy water and the good old scrubbing brush seems to work ok ....for a start ....but i had to get into mine with a stainless steel dish pad to get some of the discolouration out and expose some new metal.
doing some research into heat an cooling effects on my rt as i go along, a couple of ideas im working on.
8Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 7:15 pm
As Crazy Frog predicted, I have the answer to your questions about heat problems on the K100.
I posted an article in the How-to section on K-bike Heat Managment which points to a document in the download section of this site. The documentdescribes various methods for taming the enormous amnount of heat that is generated by the engine causing general rider discomfort in the warm summer season. Download the document and read about the various solutions, such as new fans, insulation, Jerry Blankets, hose routing, and so on.
9Back to top Go down   Dealing with the engine heat Empty Re: Dealing with the engine heat Thu Apr 14, 2011 10:27 pm
Puccini
Thanks,
It gives me good info try.
I'll let you know how it works.
P.S. I was told by a local BMW tech that aluminum cleaner that has Phosphoric Acid in it will help clean the aluminum alloy parts of the engine.
I found a gel in the local hardware store that I will try.
