1 Heat insulation Sun Aug 19, 2012 10:43 am
nino
Hello, here in Croatia no rain for two and half month with temps 35 shade, good knows on sun. I tried to get some heat insulation on RT:
- I bought 100 cm peace of rubber stripe for car windows and cianoacril glue. I glued the stripe to the inner, tank side leg protector on both sides of fairing.
Went for a ride, everything was good except heat that came to right underknee area from empty space beetwen air box and tank. So I put peace of black foam 40 mm thick under the tank.
Went on ride again and heat was tolerable even in shorties (35 degrees in shade today).
Regards
Regards
