1Back to top Go down   pannier/side case hinges Empty pannier/side case hinges Thu Apr 07, 2011 2:14 pm
kerplunk
Hi folks
Ive just purchased a K100RS and was going to be doing a bit of
refurbishment by myself. Im needing new hinges for the lids on my side
cases I cant seem to locate them does anyone now where I can get these.
kerplunk #0043074
2Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Thu Apr 07, 2011 3:05 pm
Alex_GER
Alex_GER
I guess you mean >>no 4<<. Remember, you need 2 for EACH case, so 4 in total...
Jod alles chlor, liebe Krüße,
euer KLotz
pannier/side case hinges E088Doenerschuss || Portfolio || MPI
http://www.students.uni-mainz.de/alotz/portfolio/
4Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Thu Apr 07, 2011 3:50 pm
kerplunk
Alex_GER wrote:I guess you mean >>no 4<<. Remember, you need 2 for EACH case, so 4 in total...
Hi alex
Yes 2 are split and 2 are okay but I was going to replace all 4 and maybe paint the lids
kerplunk #0043074
5Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Thu Apr 07, 2011 3:55 pm
kerplunk
kerplunk #0043074
6Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Thu Apr 07, 2011 5:02 pm
46 54 2 300 039 is the BMW OEM part number if seeing your dealer is quicker. I paid AU$8.00 for each of them, last year before my ride out West, which in Australia ain't too bad. I 'never' buy things from the dealer but once in a while I can place my fingers in the trap and not have their tips sheared off.
7Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Fri Apr 08, 2011 3:14 am
kerplunk wrote:
Hi alex
Just a word of caution if you paint the lids be very careful to clean the plastic because if Armourall or similar has been used the silicon will cause havoc.
I tried to paint the lid of a used top box and ended up just throwing it out because I could not get rid of the silicon. I even trird prepsol and no success.
8Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Fri Apr 08, 2011 4:54 am
good tip kfreak ...thanks
9Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Fri Apr 08, 2011 11:16 pm
club_c
club_c
a word on painting the lids: I painted mine glossy black, but I have to be SO careful about swinging my boots over the cases to avoid scuffing them. And they scratch easier since they are the most outboard portion of the bike (ask me how I know Evil or Very Mad) I would recommend trying to clean them with 'Simple Green' if you can get it in your area, seems to clean very well and gives a bit of gloss. You can also use 'Pledge' or a similar spray furniture wax product, which also gives good results.
10Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Sat Apr 09, 2011 12:01 am
Dubbin clear boot wax is superb as well.The surface should be clean first.
11Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Sat Apr 09, 2011 12:10 am
I won't use the polish that has silicon any more and only a wax or similar.
Many people use Mr Sheen to clean the perspex screens because it has the same refractive index as the perspex but it is loaded with silicon as is that plexus.
I clean the screen with water and a soft cloth and if it gets scratches I use Brasso to polish them out.
We sure got of topic here, Oh well what the heck.
12Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Sat Apr 23, 2011 8:39 am
IPJ100
IPJ100
Hi all,
Brasso to get out scratches off perspex !?! I'm off to try that now - my screen has - a scratch or two.
cheers Ian
Bye
I still haven't started restoring my C90. damm it pannier/side case hinges 652573
13Back to top Go down   pannier/side case hinges Empty Re: pannier/side case hinges Sat Apr 23, 2011 5:57 pm
Hi Ian,
Brasso may be a little harsh, there is a product from Meguiars called PlastX which is designed for the job and works superbly. I have been very pleased with the results.
