1Back to top Go down   idle revs k100 lt Empty idle revs k100 lt Mon Mar 14, 2011 5:50 am
archie
please can anyone tell me what idle revs should be ? ( k100lt ) my bike is ticking
over at about 1200 is this too high ? , i have checked cable free play
+ throttle stop screw just seems a little high , it starts ok runs very smooth & pulls like a train
2Back to top Go down   idle revs k100 lt Empty Re: idle revs k100 lt Mon Mar 14, 2011 7:43 am
Mine purrs at 1200, anything under 1000 sets the battery charge light off.
You can play with the idle screw, but I've found in my short time that air temperature changes (especially hot days here) will increase the idle speed.
3Back to top Go down   idle revs k100 lt Empty Re: idle revs k100 lt Mon Mar 14, 2011 8:18 am
The idle setting is 950 +/-50 rpm as per the Haynes manual in section 1-1 downloadable from this very forum. I set mine at 1000 rpm.
Of course the idle setting is the last thing you attend to after being sure your valves clearances are correct, the ignition timing is correct, the sparkies are clean and gapped correctly, and the air filter and fuel filter are clean.
