1 K75 New Member from Ohio USA Mon Nov 04, 2024 9:53 am
Jimbotron
Just bought a 1994 K75. I have had Goldwings and a Superglide HD in the past but havent ridden in 15 years. The brick I purchased was from an estate and looks pristine with 40k miles. But it has sat in a garage for while so I look forward to tearing it apart and doing some overdue maintenance. Tires are 10-12 years old so that is first and will give me an oppurtunity to grease the spline while the rear is apart. The heirs had replaced the fuel pump and it starts immediately and purrs like a kitten.
My questions for the forum is; It came with a Clymers 1985 thru 1989. Is it worth it to me to get an updated Haynes 1985-1995 or will the Clymers I have cover all my bases?
Also I intend to run 93 Rec gas in this just to keep the alcohol out. Any thoughts on what gas you K75 guys running?
Thanks for any responses.
Jim in Ohio
Jim in Ohio
