1 Leaky manifold fix Wed Jun 12, 2024 10:53 pm
lucki
Fix, well sort of. Used propane to isolate manifold leak, it was the middle one. I could see cracks at least on one side. Cleaned it up with a few applications of brake cleaner then used gasket maker silicon to slather it on the cracks, ain't pretty. Let it cure24 hrs. Just got in from a test ride, amazing! Idles rock solid drives flawless under 3000rpm.
Will replace manifolds when the snow flies.
Hope this is of some help.
