Gear position switch restoration Sat May 11, 2024 8:42 am
LifeGuard
![LifeGuard](https://2img.net/u/4211/29/48/93/avatars/487-80.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
Hey, I wanted to share with you a method for refurbishing the gear position switch in a gearbox. As is known, the rubber cover of the sensor degrades over the years and crumbles in your hands. I decided to remove the remnants and rebuild such a cover using 3D printing and TPU material. I additionally sealed everything with black flexible plastic from a glue gun. This way, we ensure the tightness of the sensor and prevent corrosion of the contacts in the future.
![Gear position switch restoration Img_1011](https://i.servimg.com/u/f75/20/55/06/10/img_1011.jpg)
![Gear position switch restoration Img_1010](https://i.servimg.com/u/f75/20/55/06/10/img_1010.jpg)
![Gear position switch restoration Img_1012](https://i.servimg.com/u/f75/20/55/06/10/img_1012.jpg)
![Gear position switch restoration Img_1013](https://i.servimg.com/u/f75/20/55/06/10/img_1013.jpg)
![Gear position switch restoration Img_1110](https://i.servimg.com/u/f75/20/55/06/10/img_1110.jpg)
![Gear position switch restoration Img_1111](https://i.servimg.com/u/f75/20/55/06/10/img_1111.jpg)
![Gear position switch restoration Img_1112](https://i.servimg.com/u/f75/20/55/06/10/img_1112.jpg)
![Gear position switch restoration Img_1113](https://i.servimg.com/u/f75/20/55/06/10/img_1113.jpg)
