1 Neutral Light Gear Position Switch fix Mon May 08, 2017 4:03 pm
leon83
Hello,
I'm rebuilding my K100rs. After completely cutting of the cockpit and trying to rewire everything I found out that my gear position indicator was broken. After removing the swing-arm I found it (my first bike ever to work on). Opened it and found out that the springs (2 of 3) were broken.
I only need a Neutral light, I'm not going to have a gear indicator. So my fix:
- I removed the two outer pins and springs
- Put 2 component resin on the inner circle, only the part for Neutral I left open
- Hooked up the Yellow / Blue cable to the Neutral light
Maybe not as fancy as a complete PLC with relays. But it does the job.
