1Back to top Go down   Gen 1 Pannier Repairs Empty Gen 1 Pannier Repairs Sun Mar 24, 2024 5:59 pm
grosbeak
grosbeak
The Gen 1 cases on my 1992 K75S were in rough shape when I got the bike. Problem areas included:
- Cracks in the cases (both large and small)
- Seal channels on the inner cases (mangled or separated)
- Seals (dried up or missing)
- Both lid restraints
- Latches (top and side)
Because fixing broken stuff is my jam, I decided to give it a try. I’ve learned Gen 2 cases are better than Gen1, and Gen 3 cases are better yet. If the repairs fail, replacements can be found.
1992 BMW K75S 0212025, 1999 Suzuki Bandit 1200 2100162
2Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:02 pm
grosbeak
grosbeak
The Cracks, Part I
Most of the big cracks were on the inner cases. A couple had been previously patched with strips of metal screwed over the cracks. My approach for most of them, big and small, was to remove the metal (where applicable), hot-staple the cracks, then fill the holes and gaps with a mouldable epoxy putty from JB-Weld called SteelStik.
Gen 1 Pannier Repairs 53606678873_a7e929bf8a_cMetal plate, screws removed by JD and Beastlet, on Flickr
Gen 1 Pannier Repairs 53606462106_071e052700_c
3Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:08 pm
grosbeak
grosbeak
The Cracks, Part II
Gen 1 Pannier Repairs 53606482096_72eaa199f2_c
Gen 1 Pannier Repairs 53607082109_973514e816_c
Gen 1 Pannier Repairs 53606741156_c7fe6ae5bd_c
SteelStik is activated by cutting off a small segment and kneading the hardener and epoxy putty together. It has a working time of five minutes, so I used it in small batches. Patches were completely set in an hour and could be sanded. But too much buildup meant a lot of elbow grease in the sanding.
4Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:14 pm
grosbeak
grosbeak
The Seal Channels
I repaired the seal channels with plastic welding and had a fair amount of success. There was an overall improvement.
Gen 1 Pannier Repairs 53602016463_17283d27f7_c
Gen 1 Pannier Repairs 53606741186_d196833c91_c
Gen 1 Pannier Repairs 53607081749_555b7a480a_c
5Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:15 pm
grosbeak
grosbeak
The Seals
The seals were easily replaced with a generic round nitrile rubber seal, 5mm in diameter. I used a ball end hex wrench to work it into place.
Gen 1 Pannier Repairs 53602016578_1d2de58719_c
Gen 1 Pannier Repairs 53600936342_acc98755ae_c
Gen 1 Pannier Repairs 53602273755_a9b04b0d30_c
Gen 1 Pannier Repairs 53602149564_8dddc980d0_c
6Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:15 pm
grosbeak
grosbeak
The Restraints, Part I
Both lid restraints had broken anchors – the original appeared to be a part of a snap fitting. I drilled those out and replaced them with T-nuts heated and imbedded into the plastic, then reinforced with SteelStik. Not sure how strong they’ll be… I’ll try to remember to go easy on them.
Gen 1 Pannier Repairs 53601804016_2730cba910_c
Gen 1 Pannier Repairs 53602273750_90c54752ce_c
Gen 1 Pannier Repairs 53606803459_8b87dc298d_c
7Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:15 pm
grosbeak
grosbeak
The Restraints, Part II
Gen 1 Pannier Repairs 53606804699_8f7dd57786_c
Gen 1 Pannier Repairs 53605611672_8d473f3da2_c
Gen 1 Pannier Repairs 53606823869_104ded1967_c
8Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:16 pm
grosbeak
grosbeak
The Latches, Part I (replacements)
The latches on the front that attach the cases to the Z-frame are still in decent shape – a little lubrication and they’ll be even better. I tried to find Gen 1 latches for the top and backs...some were available, but they weren’t cheap and matching keys were a no-go. I searched out Gen 2 or Gen 3 latches – still not cheap but easier to find – when I was inspired by a Home Depot solution someone else had tried.
I considered these first – they came in pairs, and I hoped that each pair would be keyed alike, but no luck – all four were different, so back they went.
Gen 1 Pannier Repairs 53606910124_0b5e1903dd_c
I wanted lockable latches with adjustable tension, and I found them, along with a set of four small padlocks, keyed alike.
Gen 1 Pannier Repairs 53605868587_27267f422f_c
Gen 1 Pannier Repairs 53606741301_4fa15e21b9_c
Gen 1 Pannier Repairs 53606741511_9e4a36de2e_c
9Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:16 pm
grosbeak
grosbeak
The Latches, Part II (removal)
Before the news ones could be fitted, the old ones had to be removed… which mostly involved drilling.
Gen 1 Pannier Repairs 53602015873_5eb33298b9_c
Gen 1 Pannier Repairs 53602273860_b58632b7a2_c
Gen 1 Pannier Repairs 53602015833_7c7c3bf973_c
10Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:17 pm
grosbeak
grosbeak
The Latches, Part III (installation)
This was the fun part for me. I got to mark, measure, install and adjust the latches.
Gen 1 Pannier Repairs 53608450195_2a1336d467_c
Gen 1 Pannier Repairs 53607113857_418e3cc6f9_c
Gen 1 Pannier Repairs 53607118062_9bd7ac2acb_c
11Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 6:21 pm
grosbeak
grosbeak
On The Bike
Gen 1 Pannier Repairs 53609028555_00fcde07e1_c
Gen 1 Pannier Repairs 53608572271_4de39531c9_c
[url=https://flic.kr/p/2pFeEYC]Gen 1 Pannier Repairs 53608909124_f3b12716c7_c[/url
The cases are now fully functional. They got a touch of Krylon Fusion All-In-One over the visible crack patches but that was the extent of the cosmetic work. I figure it’s a 10/10 job - looks great going 10 km/h from 10 m away!
12Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Sun Mar 24, 2024 9:08 pm
A man after my own heart! Why buy a new one when you can have lots more fun repairing the old one?
13Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Mon Mar 25, 2024 3:59 am
A nice innovative repair although I have seen it done before but using the military version of similar hardware.  GB777 will know who I mean when I mention a former President of the BMW club.
A couple things I would consider are:
Making an alloy/mild steel plate for the inner surface of the hook attached to the inner pannier as well as the outer pannier latch.  For the simple reason that I can see the hook pulling itself out of the plastic if over tightened or if someone decides to try and lever the latch off the pannier to gain access.
I would also consider applying something like heat shrink to the padlocks if they are to be fitted whilst riding.  Just to prevent scratching and noise as they bounce around.
I intend to make myself a pair of alloy panniers in the future and was considering using similar hardware to what you have there.
14Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Wed Mar 27, 2024 7:49 pm
grosbeak
grosbeak
TacKler wrote:A nice innovative repair although I have seen it done before but using the military version of similar hardware.  GB777 will know who I mean when I mention a former President of the BMW club.
Fine ideas!
I replaced the wood screws with M4 flat head hex screws, aluminum backing plates and nylock nuts.
Gen 1 Pannier Repairs 53613540878_3b580b2064_c
Gen 1 Pannier Repairs 53613540983_29cab79787_c
Gen 1 Pannier Repairs 53613541063_3404e34b5a_c
I need to pick up some bigger heat shrink, then the locks are next.
15Back to top Go down   Gen 1 Pannier Repairs Empty Thanks for the review of the work Thu Mar 28, 2024 1:10 am
QuietLT
QuietLT
I work in the Downtown Eastside of Vancouver and recently walked back to my bike having been pushed over onto the right side (along with 3 other bikes).  The right Pannier got busted up pretty badly.  Got a project now.
16Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Thu Mar 28, 2024 8:28 am
grosbeak
grosbeak
QuietLT wrote:I work in the Downtown Eastside of Vancouver and recently walked back to my bike having been pushed over onto the right side (along with 3 other bikes).  The right Pannier got busted up pretty badly.  Got a project now.
That sucks big time. Some people's children, I tell ya...
17Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Thu Mar 28, 2024 10:27 am
grosbeak wrote:I need to pick up some bigger heat shrink, then the locks are next.
Can I suggest that you shorten the bolts? Murphy is sitting here laughing and telling me that he's gonna skin the backs of your hands on the ends of the bolts.
Yeah. The little bugger's had me too.
18Back to top Go down   Gen 1 Pannier Repairs Empty Re: Gen 1 Pannier Repairs Thu Mar 28, 2024 11:19 am
grosbeak
grosbeak
Thanks Dai... good idea!
