Number of posts : 7954
The first post is about transmission and final drive, not engine.
The transmission level is quite specific. It has to be measured with a dip stick. If you have the C spanner for rear suspension adjustment, its marked with the level mark. If not, a screwdriver with a non removable shaft [so it cant fall out into the transmission- dismantle it to get it back out] and its 116mm from the top handle.
Final drive uses the same oil, to the beginning of the filler plug threads.
1 litre is not sufficient to do both, together they take slightly more.
1971 Yamaha 125 YAS-1
