1Back to top Go down   GPI screen gremlin Empty GPI screen gremlin Sat Feb 24, 2024 4:40 am
KiwiK100
KiwiK100
So the gremlins continue to haunt the rebuild of my ‘83 K100. Odometer is now working after robbing some gears from my donor instruments however I’ve noticed that while the GPI screen indicates all gear positions, each image is now distorted and fat. Can’t think of a better way to describe it and I’m fairly certain this is a recent gremlin at play. I’ve not had the bike long, and only rode it home after purchasing it, and was aware then GPI screen was blank. I subsequently found a bunch of harness wires had worn through at the steering stem and when these were repaired the GPI screen worked perfectly.  I did notice that one on the earth wires has been squashed behind the cover of the two banks of pins at the back of the cluster, however I did a continuity test in both directions and all is good. Anyone come across this before.  Any ideas as to what I may have done?
Thanks.
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
2Back to top Go down   GPI screen gremlin Empty Re: GPI screen gremlin Sat Feb 24, 2024 6:40 am
That's usually a sign of a dying LCD screen. Do you have another one to check against?
3Back to top Go down   GPI screen gremlin Empty Re: GPI screen gremlin Sat Feb 24, 2024 2:11 pm
early series lunchboxxes were really poorly ventilated (known for fogging up ) , so you could be suffering from slight corrosion sitting on the pads that the lcd connects to (through one of those flexible carbon compression connects )
if you have one of the later series meter housings (ventilated ) best to transfer the instruments over ????
4Back to top Go down   GPI screen gremlin Empty Re: GPI screen gremlin Sat Feb 24, 2024 4:08 pm
KiwiK100
KiwiK100
Thanks Charlie, I’ll investigate that and see what’s going on. The cluster has lived under a Krauser fairing for the last few decades so rarely gets wet, however it’s lived near the coast for at least the last 15 years and while has absolutely no rust on it, there is always the possibility of electrical corrosion as it’s a very humid environment here. BTW the LCD screen on my donor unit is toast.
Current rides:
The family history:
5Back to top Go down   GPI screen gremlin Empty Re: GPI screen gremlin Tue Feb 27, 2024 7:22 pm
KiwiK100
KiwiK100
Hey Charlie, I pulled the LCD screen off and made sure all the connections were spotlessly clean. Unfortunately has not made any difference so looks like my screen is on the way out.
Current rides:
The family history:
6Back to top Go down   GPI screen gremlin Empty Re: GPI screen gremlin Tue Feb 27, 2024 9:25 pm
7Back to top Go down   GPI screen gremlin Empty Re: GPI screen gremlin Wed Feb 28, 2024 5:34 am
KiwiK100
KiwiK100
Thanks Robmack, PM sent
Current rides:
The family history:
8Back to top Go down   GPI screen gremlin Empty Re: GPI screen gremlin Wed Feb 28, 2024 4:52 pm
Good to lnow ....thanks for the update.
I haven't tried it yet but there is a capacitor near the lcd driver chip a low value electrolytic one   (10uF)
I had an inkling that if that cap dried out or became leaky it could affect the  , latch disable function on on the 4543 ...or reset on the 4060
Reason fo thinking this is on "reds" gpi lcd for the first few minutes there is a faint but definite display ...which disappears after a short while
Thoughts ?
In any case i have to exchange the trip odometer cluster soon  so will get a chance  to play inside .....
