1 Electrical Gremlin Need help please. Mon Oct 03, 2016 6:47 pm
TheJoker
Hello, I'm getting along with my project bike haven't had that much time to get into it but it's getting there. Anyway the reason for this thread is I've got an electrical gremlin. Right then I installed these indicators which caused hyper flash on me (I've since learnt to remove this I can remove the solder from pin 7 on the indicator relay). However whilst working out my mess of wires a negative and positive joined together. This caused two fuses to blow (fuse 3 and 4).
Now since this my digital clock has stopped working, I've lost neutral on the instruments and it's now reading the gears in reverse. Go down and you are going up the gears. Now since the wire got tugged together I've also lost the indicators they have stopped working completely. All fuses seem to be working I've replaced with known good ones from another bike. Battery has charge as my horn is still working fine and so is the headlight.
Now every time I go to start the bike I get a weird sound like something is shorting out the system. I did have a weird wine noise when I went to actually sort the indicators before hand but this appeared only on the left hand side. Obviously something has blown or snagged but I'm having problems working out what it is.
Now on the other hand I've also got another problem I'm trying to sort out, right now I've got a dual filament bulb in the new headlight and a sidelight bulb. Now the wiring has been hooked up and the double filament works main beam and full beam. The headlight seems to get a bit warm but it works. However the sidelight I'm not sure what to do with. I've found some extra wires but I can't remember what they are for. Any idea can you identify them ?
Looking forward to the replies.
Thank you,
Sam.
Thank you,
Sam.
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
