Go to page : 1, 2  Next
1Back to top Go down   refurbish "RED" the rs  Empty refurbish "RED" the rs Sun Nov 06, 2022 4:27 am
As many may know and read of TWB's (Darren) recent visit back to aussie accompanied by the fabulous Pamela ,
and a local meet by some of the northern Mob both before and after his family visit down south
i have been fortunate and lucky enough to acquire his quite exceptional red rs .
the RS of many fabulous adventures detailed by "Dazza" around this countryside over the years .
My plan is to restore the machine up to an "charlie level" of ability .
meaning i wont have a motza (aussie term for "lots" ) of finances to throw at it but considered rework of what is currently fitted to the machine , along with general maintenance of the regular issues arising from long term storage and intermittent riding under limited timeframe visits by TWB.
fortunately Darren has been able to also supply a plethora of spares , for the bike, acquired along the path for just such things , including new fuel pump, vibration isolator mount and filter various seals , keys , spare parts for locking components , etc etc .
after getting the Beast home and up onto the centre stand ,
immediately noticed issues included
foul fuel in the tank , although nearly full to the brim
cracked headlamp glass
oil at the back of the gearbox , clinging to the centre stand pivots and legs and plastered along the swing arm and diff
missing bar end weights
bolts replacing studs at the exhaust flanges
3 keys required for ignition seat and tank and another for top box
and botched / destroyed yolk bolts damaged during an impromptu  fork swap at the storage shed on pickup day .
and so begins the battle to restore "RED"
2Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 5:33 am
so lets begin
fresh off the trailer at home after a trouble free run down the coast , then up the hills to home , behind my little , tiny even , tin box
refurbish "RED" the rs  20220910
refurbish "RED" the rs  20220911
cracked headlamp
refurbish "RED" the rs  20220912
exhaust
refurbish "RED" the rs  20221010
then to explore the drivetrain , pulling the diff and swingarm areas off
refurbish "RED" the rs  20221011
the bike looking a little more ...erm incomplete ...!!
refurbish "RED" the rs  20221012
3Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 5:54 am
some results ... possibly
found the oil leak at the gearbox to be the output seal leaking into the swing arm
cleaned up and replaced seal
refurbish "RED" the rs  20221013
additionally alternator drive seal leaking oil out of the sprag clutch area
refurbish "RED" the rs  20221014
also cleaned up , along with a clean of the starter and alternator ,  fresh paint on the battery tray after replacing broken rubber mounts , and stripped threads into the gearbox
refurbish "RED" the rs  20221015
refurbish "RED" the rs  20221016
refurbish "RED" the rs  20221017
 swing arm and diff cleaned , before and after
 refurbish "RED" the rs  20221018
refurbish "RED" the rs  20221019
refurbish "RED" the rs  20221020
refurbish "RED" the rs  20221021
exhaust removed, studs replaced where bolts once fitted  and cleaned up the pipes
refurbish "RED" the rs  20221022
4Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 7:02 am
You just can't help yourself, can you Charlie. Well done so far. Very Happy
5Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 11:44 am
only what i have posted ...so far Stan
been a busy month
all locks on the bike now keyed to one key
fuel tank replaced filter , hoses pump and cleaned out and ready to go , just to replace the external fuel rail feed pipe (rather thin )
fixed electrics on joined cables to headlight , added new switch  to dash for under fairing drls ,the switch i rebuilt adding a led for illumination when active , added switched power and highbeam feed so off is centre , on always = down , on with highbeam only = up
removed relay off heated grips wiring , and reused it for drls
relocated brake reservoir from battery plate to back of electrics box , behind side panel
replaced footplate fixings , both to the gearbox and panier frames ,
replaced brake caliper - fork guard mount bolts etc with stainless as the footplates
made bar end weights and relocated controls to mate up properly , fitted stainless allen head screws screws to the philips head electrics panel  fasteners on each perch
made an under fairing scoop as per Fred  ,
replaced right hand horn  with the correct one right hand this time instead of left  so it lines up through the holes correctly
refurbished the headlight assembly fully , including new glass (supplied from TWB )  added led lamp for parker light  and NEW led headlight to keep the current down , and the brightness up (replacing a qi lamp with only high beam actually working )
reroute various electric cables  and tidy up under tank area
added a fuse for auxilary lighting
replaced earth cable with something way more substantial
yanked a connector off the coil cover
pulled all spark plugs , test high voltage cables , and coils for good measuerements
any bolt undone has been either copper sliped or nickle sliped
replace manky alterrnator bolts and clean regulator brushes
replaced seal to starter whilst out
reinstall front guard
repair fairing left hand frame mount hole , fibreglass broken
clean and repaint internal fairing instrument mounting / baffle plates adding rubber edge buffers
clean up just about every electrical connection with deoxit
added stainless nuts and washers to rear guard mount brackets
found and replace various 5mm bolts missing from fairing holding the screen and others in place
and im sure many other little things
will likely have to pull the gearbox and replace the output shaft bearings , likely the whole  lot , and lube the clutch splines , but waiting for a run on it to determine that first .
oops forgot to mention cleaned up the whole exhaust system , from header clamps separated pipes to end of muffler
6Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 11:52 am
Bricklayer
Bricklayer
"also cleaned up , along with a clean of the starter and alternator ,  fresh paint on the battery tray after replacing broken rubber mounts , and stripped threads into the gearbox"
The rubber mounts can be repaired, if the rubber splits, by cleaning the surfaces that separated and the applying superglue and a bit of pressure while it dries.
Anthony Mrugacz
https://anthonymrugacz.net
View Past Stable of Ponies:
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
https://anthonymrugacz.net/
7Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 12:08 pm
Bricklayer wrote:"also cleaned up , along with a clean of the starter and alternator ,  fresh paint on the battery tray after replacing broken rubber mounts , and stripped threads into the gearbox"
thanks
 yes the mounts can be repaired , but , not when the thread on the bottom going into the gearbox has been fretting and actually worn the thread thin so it no longer is a 6mm thread , and it that process worn away the thread holes into the gearbox .
i had to replace the mounts for better ones , retap and helicoil the gearbox to take the replaced rubber mounts .
ill try to find one that i pulled out so you understand what i mean as i dont remember taking a good pic during the operation
refurbish "RED" the rs  20221023
8Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 12:09 pm
Bricklayer
Bricklayer
I understand, I was unsure if you had any with split rubber and was unaware.
Anthony Mrugacz
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
9Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 06, 2022 12:13 pm
refurbish "RED" the rs  112350
i find it fairly common on the older ones that have done a lot of country road exploring .
10Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Nov 07, 2022 11:26 am
Rochen
Rochen
What do you use to clean the entire engine area in depth without damaging the gaskets and rubbers?
11Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Nov 07, 2022 12:52 pm
a cheap degreaser   and a dremel tool with small steel brush , or a nylon brush on a battery drill , depending on what i have at the time and the job at hand ,
welll that one way to clean but leave the sandcasting marks as original
12Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Nov 07, 2022 1:02 pm
bar end weights turned out ok , and now fitted up , adjusted grips and perch to suit
refurbish "RED" the rs  20221110
refurbish "RED" the rs  20221111
under fairing scoop fitted prior to drls going in
refurbish "RED" the rs  20221113
also stripped out clutch arm and lubricated adding grease nipple
pulled the radiator and flushed and washed the fins of grit and crap , a fair bit came out actually , a 3 core type
refurbish "RED" the rs  20221114
 the temp sensor in the water riser stub was the cleanest i have seen to date including the thread in the stub , coated with copper slip and back in
refurbish "RED" the rs  20221115
13Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Nov 07, 2022 3:28 pm
Good old ocky strap holding the mirrors in case they are dislodged. Smart thinking and preventative measure.
14Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Nov 07, 2022 11:47 pm
Good move cleaning the fins on that radiator.  Dirt and wildlife packed in those spaces caused serious overheating on one of my K100's.  That fin flush is now a part of commissioning every "new" bike that comes to my garage.
15Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Nov 10, 2022 9:05 am
To add to Charlie's comments on the battery anti-vibration mounts: the top left one in his picture is a blind hole. The other three have threads that go right through. If you can't helicoil then you can drill and tap to 8mm thread. For that blind hole, once I had tapped as much as possible with the normal three taps, I ground a final tap so that it was almost flat across the end and exposed only full threads so that I could rethread as much as possible into that blind hole.
16Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Nov 10, 2022 2:08 pm
Indeed Dai  done thst before  just had a "BOTTOM TAP AT HAND    then it went in smoothly
17Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Nov 10, 2022 2:22 pm
battery going in ,stollen out of FRED , for the moment
thought to put a rubber vibration damper on the tray before installing the battery
refurbish "RED" the rs  20221116
refurbish "RED" the rs  20221117
at least the restorers club registrar has cleared it for roadworthyness , given that fairing parts to go on are low risk  and all other functions are working correctly ...yippee
18Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 12, 2022 2:15 pm
some success today on the bike out of the storage shed "RED" ,
literally just placed the tank on the frame and added a couple of litres of fuel , a couple of pushes of the start button to prime the fuel system
, a really rough engine tick over resulted , missing on a couple of cylinders .
 injector exercise got them working after being frozen by evaporated fuel for 4 or more years ,
a second start had all 4 cylinders running with a reasonable idle some little while later .
woohoo !!!! took some vids , which will come soon
19Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 12, 2022 3:12 pm
zaubertuba
zaubertuba
charlie99 wrote:a second start had all 4 cylinders running with a reasonable idle some little while later .
WOOT!  That's gotta be a good feeling, after all that work. Bravo!   Cool
1985 K100RS
20Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 12, 2022 4:21 pm
Cheers  , thanks for commenting
And yes good to get a result, indeed
21Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 12, 2022 5:22 pm
cheers what are you naming the new addition to the family.
22Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 12, 2022 6:06 pm
Not sure yet martin   but for the moment RED seems to fit nicely......lol
23Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 12, 2022 6:13 pm
Erica the red???
24Back to top Go down   refurbish "RED" the rs  Empty Refurbish red Sat Nov 12, 2022 7:29 pm
daveyson
daveyson
So as not to get confused with your red frame, how's about Fred the Red? cause that's even more red than Fred.
 ~120,000 km
25Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 12, 2022 8:19 pm
lol!
26Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Nov 13, 2022 6:58 am
daveyson wrote:So as not to get confused with your red frame, how's about Fred the Red? cause that's even more red than Fred.
refurbish "RED" the rs  44271 refurbish "RED" the rs  44271
Yep - I'm with that!
27Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Nov 17, 2022 3:53 am
Nice work Charlie, old Ks will always come back with a bit of TLC.
Pleased to see that you have inherited the rear suspension stud support that I made for Darren, keeping it in the family!
Cheers,
28Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Nov 17, 2022 5:04 am
mike d
Hi Paul,
Good to see you posting again.
Mike (BMW Club UK).
29Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Nov 17, 2022 5:45 pm
sidecar paul wrote:Nice work Charlie, old Ks will always come back with a bit of TLC.
Cheers,
oh wow , good to see you Paul
yes as soon as i set eyes on the bike i noticed that little gem of a thing quietly doing its fabulous stuff
like the one on Gerty , that would have to be 8-9 years old now ?
fabulous work olmate , nothing like the original SCP stud brace
many thanks
30Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Fri Nov 18, 2022 1:58 am
It is good to see that the choice was well-made as to whose calloused hands and knowledgeable mind might best attempt to resurrect ol' Red. The bike had sat too much between my less and less frequent trips home, then roused from storage shed slumber to do a month-long slog between Queensland and Victoria, often laden with pillion and gear.
I must say hearing her (I always referred to it in the feminine) fire, clear and tick-over gave me mild homesickness. That new rear Progressive-brand shock and Paul's finely crafted stud support worked together in concert quite well in the past on OZ's rough (and getting rougher) roads, as witnessed by our sodden hire car road-trip last month.
There is a lot of life left in Red, thanks to my old mate Charlie. How'd she roll?
31Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Fri Nov 18, 2022 6:00 pm
hi Dazza
well the old girl certainly does move along , although the front end does appear rather tight on the many potholes around the area
id be guessing the profile of that radial out front  and likely replenishing the current fork oil with some lighter oils may let the forks do more movement with less jarring.
still a few things to do ol mate , which i shall document as i can get to them
solved an alternator no charge issue , bloomin led in the instruments , now duplicated in the fuse lunchbox with a globe in a housing , until i go in there to sort a number of issues , sometime in the future
started work on paint issues around the front of the engine being blasted off by road grime - grit
refurbish "RED" the rs  20221118
repainted the hall effects cover which now looks great
refurbish "RED" the rs  20221119
and a spare water pump cover , but just masked up the current one and blaster it , until i go into the cam cover and repaint that also
refurbish "RED" the rs  20221120
and still to put some fresh exhaust gasket o ring to eliminate some fluffing
but all good so far
more to come
32Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 19, 2022 12:48 am
That instrument cluster has a Duck-supplied LED set in it, since 2008 or '09, best guess. It always charged plenty, and we know things can change, unless you're referring to the usual late to extinguish/rpm delay.
You'll note a fresh set of exhaust crush washers, (possibly studs) & copper nuts including in the copious supply of spares, intended for a rainy day.
As you know those are the original RS forks, spent a dozen-plus years bolted onto the Airhead, most of that in storage. Dunno when the oil & accumulated sludge was drained from them. Prolly last decade.
Last time home (2018) I did the steering head bearings, carefully massaging flat the protection plate beneath the bearing on the lower triple - I did not have a simple repacement at the time.
Oh, it's good to see her begin to shine again. That engine was always an eagre one for the road ahead.
33Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Nov 19, 2022 8:11 am
34Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Dec 08, 2022 10:09 am
refurbish "RED" the rs  20221210
35Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Dec 08, 2022 11:52 am
And what a historic vehicle it is. cheers
36Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Thu Dec 29, 2022 11:06 am
so after checking valve clearances and changing 4 inlet to get about 8 thou  instead of 6 to match the others
decided to repaint a spare cam cover that had decent marks all over it
a bit of prep took out some marks and cleaned up rough ground patches
and then some new to me paint , a satin black
refurbish "RED" the rs  20221215
 then cutting in the profile ridges to produce a more recognizable look
refurbish "RED" the rs  20221216
found another spark plug cover to which i did the same treatment
refurbish "RED" the rs  20221217
and finally  both the parts together after a bit more finessing
just debating if i should clear coat it with a crystal clear ....?
 refurbish "RED" the rs  20221218
what im trying to replace
refurbish "RED" the rs  20221219
37Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Jan 21, 2023 3:30 am
some exploring - testing with mates  last weekend,  over to Dorrigo , and back the same way for me .
i had changed the "big wheel " 4.5 inch 1100 rs rim and tyre  for a standard k100 y spoke  with vintage tyre , just for fettling .
and wasn't going down the gorges to Grafton from there , especially after all the big rains around these parts .
Everything ran well .
refurbish "RED" the rs  20230112
a week later preparing for a Club day Ride  to the "Lamb and Potatoe" Festival with the Inverell Restorers Club (whom i have all my historic registrations with )  down at Guyra , we also have a local "New England Classic Kbike " group on facebook which i'm hoping a few members will turn up for , if not on bike , just to say G'day .
big wheel back on .
well it started raining didnt it , was expected with several days of wet predicted , Bugga !!!
oh well washed and waxed will have to do , with a wipe over to remove all the grit from the roads as i get there eh ?!!
refurbish "RED" the rs  20230111
38Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sat Jan 28, 2023 11:58 am
Good to see her out n about again, Chazza. She was always a good strong runner, now must be nearer purrfect.
Laughing
39Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Jan 29, 2023 5:02 pm
tinyspuds
tinyspuds
She looks stunning Charlie.
40Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Jan 30, 2023 5:40 am
fishboy316
fishboy316
She looks Soooo Good! Love a red K100, but then I am kinda partial!
41Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Jan 30, 2023 5:53 am
That metallic red colour is a nice respray - the original colour was Motorsport white - done by the gent who imported it from Holland to OZ in the late '80s. It could use some touch up, especially near the petrol cap, and in some slightly scratched fairing panels. But when clean it glows.
42Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Sun Mar 19, 2023 7:21 pm
indeed it does ....
took a trip out to a bash in the backlots around here last weekend ,Graman pub actually (which we stayed at on one of our new england tours , some time ago , new owners now ...thank heavens )
and walked away with a bit of a bonus ,  before the rains fell , quite heavily all the way home .
Red was one of a kind in those Harley infested regions
refurbish "RED" the rs  20230315
this weekend out on the "Black dog ride day " (australia wide )
took Red up to tenterfield with the locals ,
cleanup after
refurbish "RED" the rs  20230316
refurbish "RED" the rs  20230317
43Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Mar 20, 2023 3:33 am
RS Rider
RS Rider
Beautiful bike. Love the colour.
44Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Tue Mar 21, 2023 1:52 am
Good to hear she's getting out & about, & to see she's looking good, & a prize, too! A testament to the refurb(er)  Laughing
Is that an extended rear mudguard, Chazza? I don't recall it sweeping that low before.
45Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Tue Mar 21, 2023 5:48 am
Hi Darren , yes added a bmw extension piece
Soon to add an extension to the front as well
Too many rocks and crap on the roads around heee  so i want to add a little more protectiin ..
46Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Tue Mar 21, 2023 6:23 am
Well done Charlie you can always add the new and improved Bucket Flap to protect Red.
47Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Tue Mar 21, 2023 3:36 pm
Jamie64
Jamie64
Well done, i looks even nicer in RL.
48Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Mon Sep 25, 2023 2:17 pm
just an update ,
as we're heading to the k-bike 40th celebrations soonish .
some time ago i noticed some roughness in the front end , turns out the was no spacer in the front wheel between bearings , and the little one 6005 was really grinding away with some noticeable notchyness on the other .
refurbish "RED" the rs  20230918
was able to find a standard spacer , and cut it back to 57 mm to fit the 3 spoke rim , new bearings and all much better
mean while thought to recoat the foot plates , which turned out quite nice
before then afters ,,,,
refurbish "RED" the rs  20230919
refurbish "RED" the rs  20230920
refurbish "RED" the rs  20230921
refurbish "RED" the rs  20230922
refurbish "RED" the rs  20230923
as usuall for me all pivot pins and mount screws replaced for stainless alternatives .
after heading to and from Brisvegas for the 100th year anniversary , thought i would need new rubber to make the trip south for the k-fest
the michy road pilot now pretty squared off and maybe not road worthy with at least 1400 klm to traverse later this week.
so prepared another big rim, painting it to match , wheel tape to install after fitting thee rubber .
refurbish "RED" the rs  20230926
refurbish "RED" the rs  20230924
tyres fitted up
refurbish "RED" the rs  20230925
49Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Tue Oct 17, 2023 7:22 pm
Just fixing up a rough idle rs for a local.
No gear indication pr start , except for clutch bypass   ...and fuel level lamp on at strage times   had me pullibg the thing apart , finding leakage out the gearbox weep hole
Anyhow gpi switch replaced and instruments attended including recalbrating the speedo
Today big clean up in the shed
And finally took all the rs versions out into the sunlight  ...at once
Not seen before
My rs lineup all at the same time
refurbish "RED" the rs  20231015refurbish "RED" the rs  20231015refurbish "RED" the rs  20231016
50Back to top Go down   refurbish "RED" the rs  Empty Re: refurbish "RED" the rs Wed Oct 18, 2023 6:21 am
Looking good Charlie. You need a blue one and then you can do a patriotic red, white and blue display.
