back again with more work on the "red" bike
been pretty cool around here last few weeks , with max temps around 8 c and minimums of about 2c ...yes wet easterly winds and rain
so pulled the instrument cluster off , with the intentions of fixing the trip meter
the fault was that when resetting it would only mesh with 10s units ...making setting back to zero , rather tedious
no real issues there as i had a spare unit in the library , and only 2 screws fix the mechanism to the odometer part
then whilst there resolved a couple of night illumination lamp issues , the main issue was the bulb holders spring metal had diminished making intermittent contact with the film circuit board ,
issue sorted , Plus changed the globes from green leds to white ones , adding an additional led behind the 60-80 klm region of the speedo
then thought , why dont i solve that gear indicator lcd issue , being that it had faded to nothing .
i replaced the oscilator chip on the gpi board , hoping that the oscillator driver had failed ...no go ...so resolved that the lcd had just leaked away to nothing .
ah ha .... 0.4 inch 7 segment led indicator purchased and did the mods for installing it through the circuit board , with a backing pcb for termination .
worked out quite well , but had to route connections around the backing support bracketry under the board
all fixed and ready to go back in ......yipeeee !!!!
