1Back to top Go down   introduction Empty introduction Mon Aug 14, 2023 12:54 pm
ming
ming
hi chaps,
i have a very badly built k100 1988 that has been badly cafe racered and i am in the process of sorting all the issues out wilth it. i am particulary interested in anyone who has down a rear wheel swap for either k1200 rims or 1150/R9t wheels as this is my starting point, once this problen is solved i can move forward with the reat of the build.
have just completed my spondon bandit and wanted another project to get my teeth into and really liked the look of the k100 cafe racer, i have access to some fantastic engineers and fabricators near me so nothing is off limits!!
ming
2Back to top Go down   introduction Empty Re: introduction Mon Aug 14, 2023 1:13 pm
Welcome from across the water. Spondon Bandit is something unusual, Spondon more normally associated elsewhere.
I will say welcome here but you should start a new thread for your build.
3Back to top Go down   introduction Empty Re: introduction Mon Aug 14, 2023 1:40 pm
bad boy
bad boy
hello ming
introduction 177912
Cheerz, David
introduction 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
4Back to top Go down   introduction Empty introduction Mon Aug 14, 2023 1:50 pm
ming
ming
thanks m8
spondons not that unusual, theres a few about, they originally started making frames for TZ 250/350 and then later on frames for just about anything you could think of! and they are 5 miles from where i live, unfortunately they no longer exist due to the norton fiasco but spondon GIA is still up and running a bit further down the road. how do you go about posting up images?
thsnks again
5Back to top Go down   introduction Empty Re: introduction Mon Aug 14, 2023 1:55 pm
firstle
firstle
spondon , love the shape , i had a rob north trident t150 some years ago , wish i still had it i think it went to holland .
6Back to top Go down   introduction Empty Re: introduction Mon Aug 14, 2023 2:02 pm
ming
ming
yeah lovely thing the rob north frames, they had one in the motor vehicles department at university, someone there occasionally raced it, probably worth more than a spondon!
7Back to top Go down   introduction Empty Re: introduction Tue Aug 15, 2023 12:28 pm
fishboy316
fishboy316
Hello Ming. Welcome!
8Back to top Go down   introduction Empty Re: introduction Tue Aug 15, 2023 1:43 pm
ming
ming
'ello m8
9Back to top Go down   introduction Empty Re: introduction Tue Aug 15, 2023 2:30 pm
Suzi Q
Suzi Q
The R1100/1150 series rear wheels have a compatible stud pattern, but the disc is mounted on the wheel, rather than on the drive hub. The R series wheels therefore have more offset, since they are not made to be spaced away from the hub by the thickness of a disk sandwiched between them. This can be overcome very simply by using the R series wheel-mounted disc. They have a narrower track than the K series, so it is necessary to use a matching brake caliper. The caliper mounting holes are in the right place if you do this. I found that axial alignment was the only issue, and this was sorted by a combination of machining the disc mounting posts on the wheel, and making spacers for the caliper mountings. It's described somewhere on the thread for K7kforkurz.
I used a 5" rim with a 170/60 17 tyre and it sits almost central.
10Back to top Go down   introduction Empty Re: introduction Tue Aug 15, 2023 2:35 pm
ming
ming
thank you m8, that was super helpfull! felt like i was going round and round getting no where and was reluctant to comit to buying a wheel!
thanks for the info
ming
11Back to top Go down   introduction Empty Re: introduction Tue Aug 15, 2023 2:36 pm
Suzi Q
Suzi Q
I've just realised that you've resurrected an old thread where I more or less said the same stuff. Good luck with your build!
12Back to top Go down   introduction Empty Re: introduction Thu Aug 24, 2023 5:50 am
Bernie_K100
Bernie_K100
Hi,
introduction 177912 to this forum!
Bernie
