FrancescoAuteri
FrancescoAuteri
1990 K 75 C owner, 59k miles, on a tight budget. Familiar with small to 4L engine repair. My bm-r is in need of a new timing chain, most likely. Maybe the lambda sensor, and then some. I'm interested in buddying up. Please contact me. Thanks.
Timing chain is usually never worn on these engines. You probably don't need to change it.
And, good new, you don't need to change the lambda sensor as K75 never had one.
That fills our fairest day.
Welcome!  As JBT advised, you don't need a timing chain or lambda sensor for your engine.  Most of these bikes at this stage need new rubber bits like the crankcase breather hose and the throttle body vacuum caps.  Another often replaced item is the coolant temperature sensor.
What is the problem you are having with your bike?
Where is River Forest?
Point-Seven-five wrote:Where is River Forest?
There's one in suburban Chicago. cheers
bad boy
bad boy
hello FrancescoAuteri
Greetings, thank you for your consideration. 177912
Cheerz, David
Greetings, thank you for your consideration. 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
fishboy316
fishboy316
Hello, Welcome!
Bernie_K100
Bernie_K100
Hi,
Greetings, thank you for your consideration. 177912 to this forum!
Bernie
