1Back to top Go down   41.3 dia. K100 front fork Empty 41.3 dia. K100 front fork Sat Aug 12, 2023 4:19 pm
arbalest
Can anyone point me to a 41.3 K100 fork diagram? The MAX BMW Parts Fiche diagrams shows two damper drawings and one fork leg drawing.
2Back to top Go down   41.3 dia. K100 front fork Empty Re: 41.3 dia. K100 front fork Sat Aug 12, 2023 5:00 pm
There were 2 version of that fork, based on the very good Marzocchi M1R.
The left tube is damping compression, the right one is damping rebound.
The 1st had classical "open" damper, with a stack of washers.
The 2nd had a cartridge damper.
The tubes are specific for each type and can't be mixed.
Use https://www.realoem.com/ for exploded views.
That fills our fairest day.
3Back to top Go down   41.3 dia. K100 front fork Empty 43.1 K100 fork Sat Aug 12, 2023 7:11 pm
arbalest
jbt wrote:There were 2 version of that fork, based on the very good Marzocchi M1R.
Thanks. I will check it out.
4Back to top Go down   41.3 dia. K100 front fork Empty Re: 41.3 dia. K100 front fork Sun Aug 13, 2023 4:48 am
firstle
firstle
is there any way to id which forks you have from the outside , top etc , or is the only way to strip the forks ?
5Back to top Go down   41.3 dia. K100 front fork Empty Re: 41.3 dia. K100 front fork Sun Aug 13, 2023 6:31 am
AMHO, only by stripping the fork.
