1 Best way to remove rusty exhaust? Thu May 11, 2023 4:06 pm
Snod Blatter
Hi all, need input/opinions.. I'm trying to do a clutch spline lube and a clutch friction plate thickness check/replacement before heading off into Europe in the second half of June. and after watching Chris Harris make the whole thing look easy I've got as far as trying to get the exhaust off. This is taking some time.. Basically, I've undone the four clips where the individual, umm, downpipes (??) go into the collector/muffler but for the life of me I can't get the muffler to come off the end of these pipes, even with hammering a bit of wood pressed against it. I don't really want to do anything more abusive to it.
So I looked into taking the exhaust off the engine, like our lord and saviour Harris claims is easier, but I have a problem that he didn't seem to encounter - serious rust. The nuts are no longer nut shaped, after scraping a spanner around them they are just round bits of rust stuck on to the studs:
But the clamps do surely look like they need replacing, they seem quite warped. So if I hammer a socket on to these, does anyone reckon the studs might turn out? Or are they likely to snap? I don't want to scupper myself like that with so little time to go. And if touching these is dangerous, does anyone have any tips for getting the muffler off?
Otherwise, this job is just a nightmare, balancing the bike on bricks and wood so I can take the stand off is crazy, and I can't get one of the bolts out of the bottom mounting of the Z rail and the exhaust side because it's stuck in the footpeg bracket, and I've barely even started yet!
1989 K100RS SE ABS 8v VIN: 0149214
