1Back to top Go down   k1100 wheels  Empty k1100 wheels Mon Apr 10, 2023 9:48 pm
firstle
firstle
do the k1100 3 spoke wheels fit the k100lt ? thank you
2Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Mon Apr 10, 2023 11:37 pm
Short answer Yes but there is a lot of work to do. The 3 spoke K75 wheels are a direct swap.
3Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Mon Apr 10, 2023 11:58 pm
The K1100LT wheels are set up for a different brake system, especially the front.  Different diameter rotors, different calipers, and different fork legs.
4Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Tue Apr 11, 2023 1:11 am
firstle
firstle
the rear looks to be a fit , im not sure about the front yet but i dont think it will fit , the forks in the bike have the two part guard and a fork brace as standard but not the four piston callipers , i picked them up today and they are in nice condition with tyres , was hoping for a straight swap over   Crying or Very sad maybe not
5Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Tue Apr 11, 2023 1:37 am
The K1100 forks are a different diameter so you also need to swap in K1100 fork trees in addition to the forks and brakes. You pretty much have to swap in a complete 4V front end. But you do get better brakes and forks out of the swap.
k1100 wheels  K75sr_11
Another option is to use the current forks and fab some custom adapters for the calipers like Special K Larry has done. (But don't put the rotors on backwards like Larry did. Laughing)
k1100 wheels  Specia10
6Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Tue Apr 11, 2023 1:38 am
The rear wheels have two different part numbers and despite being the same size(3.00x17) there is a suffix(A & B) that differentiates them.  I suspect it may be that one is for a Paralever final drive and the other for a Monolever.
7Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Tue Apr 11, 2023 3:19 am
I successfully used a three spoke 18" K75S front wheel with a 110/80R18 radial tyre, along with a three spoke 18" K1100RS rear wheel with a 160/60R18 radial tyre out back, for many years on my K100RS 8V. It's still rolling like that in northern New South Wales, as far as I know.
8Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Tue Apr 11, 2023 4:22 am
firstle
firstle
may fit the front and see exactly what im up against , thanks for your help
9Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Fri Apr 14, 2023 12:37 am
firstle
firstle
i think i know the answer , but do the 4 piston callipers fit the lower legs of the two piston type  Crying or Very sad
10Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Fri Apr 14, 2023 6:05 am
See other post! Very Happy
11Back to top Go down   k1100 wheels  Empty Re: k1100 wheels Mon Apr 17, 2023 12:16 am
Moved to Frame, Fairing & Wheels, from General Discussion (for ease of locating in the future).
