1 do the 4 piston callipers fit the lower legs of the two piston type Thu Apr 13, 2023 4:14 pm
firstle
i may try and upgrade but unsure if i will need to mill a adaption plate
Dai wrote:You'll need an adaptor plate. The offset for the mounting holes is completely different for the two types of caliper. In truth though, having run both four-pot and two-pot calipers on a Moto Guzzi T3, I found that the difference in braking effect was almost negligable so I went back to the two-pot calipers for simplicity. Weight-wise, the T3 and the K100 are pretty close; additionally, the calipers are the same diameter pistons so the comparison is a valid one. The K100 caliper is coded P08 and the Guzzi caliper is coded F08 (although it's sometimes incorrectly called P08 too). The difference between the two is that there is a 4mm greater offset for the mounts on the F08 and P08 has threads in the mounts, but the bodies are identical.
K100-forum.com » Technical, repair and troubleshooting » Frame, fairing and wheels » do the 4 piston callipers fit the lower legs of the two piston type
Similar topics
