1 86 k100 Spark Mon Apr 24, 2023 9:44 am
boomhour
I have a 86 K100 that I'm rebuilding from the ground up. before I started the rebuild process the bike ran fine. fast forward 9 months and I've rewired utilizing the m-unit blue and schematic from Mikey from Piha. I don't have the gas can on the bike yet as I want to verify spark before I install the tank over the m-unit.
My issue is that I'm not getting any spark when I ground a plug and hit the starter motor. the starter and battery are in good shape. the starter sounds strong. bike is in neutral for this test. plugs and wires are new and the correct 5ohm resitance type with bosch plugs. I have also tested the coils and they ohm out without cross talk signals. I've tested power at the ignition module and fuel injection module and everything seems good from what I've tested. the temp sensor is brand new and installed per schematic.
I think everything is install and working except for the signal that tells the bike to spark. I've read that the signal comes from the hall sensor. how do I test the hall sensor? when I hit the starter should I see the hall sensor turning? right now I see nothing moving at the hall sensor when I hit the starter and am confused as to how the spark signal is initiated?
thanks for your help!
