1 1994 K75S - Troubleshooting No Spark Tue Jun 04, 2024 7:27 pm
lethaljd
Hi Gents,
I'm most of the way done wiring up an M Unit in my 1994 K75S. I used Zach Ross's wiring layout (found here https://www.k100-forum.com/t11686-m-unit-wiring-bmw-k)
I'm not getting any spark at the plugs.
Please ignore the messy wiring. I want to get this running and then go back and tidy things up a bit and have made a real mess of things chasing this gremlin...
The starter engages and engine turns over
Fuel pump turns on
Injectors spray (I haven't seen it but there is fuel on the plugs when I pull them out)
There's power at the coils
The plugs are new Bosch X5DCs with new spark plug wires from Euro Moto Electrics. I tried swapping out the wires and going back to the factory wires with no luck.
I've been through Bert's troubleshooting diagram and run up and down the wiring, testing grounds, etc.
Found two interesting things:
1) Pin #3 on the female connection to the ICU - when testing for continuity with ground at the battery measures pretty high. I'm getting 1kOhm
2) When I test continuity on Pin #3 of the female ICU connector while pressing the start button I get some weird results on my multimeter. It cycles between a reading and Open Line. Video uploaded to Youtube below.
Is this expected? Bad Hall sensor? Do I need to go back to the troubleshooting drawing board?
Fuel pump turns on
