1Back to top Go down   Replace K100 AFM by a MAF Empty Replace K100 AFM by a MAF Mon Sep 26, 2022 8:05 am
jcd06
jcd06
The idea started in Beamers excellent thread about Bosch air flow meter restoration
https://www.k100-forum.com/t11055-bosch-air-flow-meter-restoration-summary
but it is better to make a separate thread for it.
Using MAF on the K100 has been tried before but I couldn’t find any working (and driving) example.
Let us know if you do.
The K100 uses a vane-type airflow meter (AFM).
Mass airflow meters (MAF) didn’t exist in the early eighties or were expensive or unreliable I don’t know.
First MAF versions used a thin heated wire and can I imagine they were somewhat fragile.
Present-day MAF use a hot film and that looks much more robust.
Nowadays MAF are common, inexpensive and reliable, and they offer an attractive alternative to the AFM.
Prices vary from roughly 25 to 150€.
Compared to AFM, they cause less restriction of the airflow, they are less bulky and they are available on the market, while the original AFM is available as second hand item only.
Disadvantages of the use of a MAF. The measuring element can accumulate dirt from a poor air filter or oil from an over-oiled cotton gauze filters (K&N and co), causing erroneous measurements.
There is a major challenge in using a MAF instead of AFM. They have a different output signal versus airflow and thus require another ECU or a signal converter.
Aftermarket ECU is rather expensive and absolutely not plug-and-play.
It’s the signal converter way I would like to explore. It’s less invasive compared to the ECU path.
Is it worth ditching the AFM in favour of a MAF?
Depends what you want. If you’re happy with your bike and you don’t like experiments than don’t go for it. As such, the K100 was and still is a very good design.
For me it’s a technical challenge and I love that.
As the MAF will cause less resistance to airflow it should in principle yield some extra power,  although I don’t expect to gain more than a leg of a horse.
So one will need a signal converter to modify the MAF output signal to the AFM input of the ECU.
There are probably more but I found two companies offering this as a finished product
http://max.pilotpowersupply.com/product/pilot-vaf-to-maf-converter-with-a-bluetooth-interface/
https://splitsec.com/wp-content/uploads/technotes/TN2_AFM_to_MAF_Conversion.pdf
The price of the second one gets pretty close to the order of magnitude of the price of an aftermarket ECU so I will not further investigate it.
Please let us know in case you know other.
I posted somewhat in the Pilot Engineering support forum and I’m waiting for an answer.
They are based in Kyrgyzstan and they just recently had a military conflict with a neighbouring country, so I’ll give them some time credit.
Meanwhile I'll try to find some time to have a look at the software and how to deal with the IAT sensor in their setup.
One will need a MAF regardless of the converter used, and for sake of simplicity it would be best if we all used the same.
Could we agree upon a MAF to be used for the K100 engine?
There is s few Bosch AFM listed in this catalogue
https://www.bosch-ibusiness.com/media/images/products/sensors/xx_pdfs_1/sensors_i-business.pdf
Keep a local copy of the pdf because these links appear to change regularly.
A 1000 cc 4-stroke engine at 8000 rpm assuming a volumetric efficiency of 100% will pump 4000 litres/min.   At 1.25 g/l air this would be 5 kg/min or 300 kg/h.
I would suggest the 0 280 218 440 with a measuring range till 480 kg/h. It's the smallest in the catalogue anyway. The 60 mm outer diameter will probably connect to the existing duct and fit in the air filter box.
Any suggestions or remarks?
* Train dogs. Teach people.
2Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Sun Oct 09, 2022 6:55 pm
long way from home
long way from home
Watching with interest
Andrew
3Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Fri Oct 14, 2022 6:52 am
jcd06
jcd06
long way from home wrote:Watching with interest
I hope you're not hurried Smile
I exchanged some emails with a guy from Pilotpowersupply.
For reasons unknown to me they can accept only cryptocurrency at the moment.
I'm too old for that  Rolling Eyes
And we will NOT discuss geopolitics here 🙂
The Split Second PSC1-009 Programmable Signal Calibrator AFM to MAF HV Output is the one we need for our vehicles that have an AFM with a greater than 5V output.
It's in the list of discontinued products.
I contacted the company to ask if there is any chance to have it produced again. I think the chance is small. We'll see.
I'm in contact with some people to explore the possibility of using an Arduino board for the signal conversion.
Older bootloaders caused a startup delay of about a second. Newer ones should be faster.
Code:
whatever faster means when you have only ones and zeros to count with
During this delay time, the circuit cannot output any signal which means the ECU is not able to start the engine.
One second is not the end of the world but at the best it's inelegant.
I'm used to press the start button and then turn the contact key. That would perhaps not be appropriate anymore when this delay exists.
It shouldn't be too simple, otherwise it's no fun.
The original AFM looks like being fed from the battery voltage through the IAT resistor, which is rather confusing.
That could mean battery voltage variations might show up as AFM output voltage variations.
I'm gathering EFI wiring harness and components of my previous K to make a setup allowing me to measure some real circuit behaviour.
I wish I could gather time so easily...
4Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Fri Oct 14, 2022 9:30 pm
long way from home
long way from home
lol!
Andrew
5Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 01, 2022 5:13 pm
jcd06
jcd06
I'm still trying to find out how Bosch made this EFI working.
The air temperature sensor being tied to the AFM potmeter makes things somewhat tricky.
I found an interesting quote here
https://www.kforum-tech.com/electrical/EFI/bike-wont-start-EN.htm
When the engine revs under 900rpm, the EFI computer doesn’t take into account all the data collected by the air flow meter. It collects only the air temperature and adjusts the fuel injection accordingly.
I can't simulate this particular behavior here in my setup. Does anyone know the source of this information?
Replace K100 AFM by a MAF 20221111
6Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 01, 2022 5:51 pm
long way from home
long way from home
Over my head, but wish you luck
Andrew
7Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 01, 2022 6:24 pm
I don't know whether this would help. Try your local technical library or eBay, I think it's been out of print for a while.
Replace K100 AFM by a MAF 20221210
Replace K100 AFM by a MAF 20221211
8Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 01, 2022 7:37 pm
jcd06 wrote:When the engine revs under 900rpm, the EFI computer doesn’t take into account all the data collected by the air flow meter. It collects only the air temperature and adjusts the fuel injection accordingly.
I only know my source of that information—p.27 of BMW's Level 2 LE Jetronic Manual.
Replace K100 AFM by a MAF Scree221
9Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 01, 2022 9:07 pm
The Jetronic doesn't read the air flow at idle speed(anything less than approximately <1050rpm) because there is essentially no deflection of the air flow flapper and virtually all the air is going through the air bypass.
The air temperature is measured and the data does a fine adjust to the idle mixture to compensate for the air density.
10Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 01, 2022 9:25 pm
Point-Seven-five wrote:The Jetronic doesn't read the air flow at idle speed(anything less than approximately <1050rpm) because there is essentially no deflection of the air flow flapper and virtually all the air is going through the air bypass.
It's measuring the air temperature and making adjustments based on that, not air density.  If it measured the air density then the altitude plug would not be necessary.
11Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 01, 2022 10:44 pm
PV=nRT says the amount(n) of a gas/air at a given (P)ressure and (V)olume is inversely proportional to the (T)emperature.  R is just a constant that adjusts for the molecular weight of the gas in question
At idle the density of the air entering the engine is inferred by the Jetronic from temperature.  Lower temperature = more air.  It's why drag racers like running on cool days, more air gets in the engine.  Density defines the mass of the air going in the engine and the fuel needed for proper combustion.
At higher altitude the pressure that results from having a shorter air column above you affects the compression of the air molecules resulting in less density for a given temperature.  That change in atmospheric pressure is what the "altitude plug" is compensating for.
12Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Fri Dec 02, 2022 3:53 am
jcd06
jcd06
Thanks guys. Back to work now  Very Happy
13Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Tue Dec 06, 2022 8:16 am
jcd06
jcd06
Laitch wrote:I only know my source of that information—p.27 of BMW's Level 2 LE Jetronic Manual.
That is very useful thanks.
I agree for the temperature measurement and the mixture compensation but I found the airflap is responsive at idle (at least on my K).
I measured the voltage between pin 7 and ground at various working conditions:
14:14h   4.79V     just after cold start, choke on, throttle closed, ±1000rpm
14:19h   4.90V     choke on, throttle closed, ±1000rpm
14:20h   1.83V     choke off, throttle closed, ±800rpm
14:24h   2.20V     choke off, throttle closed, ±850rpm
14:24h   4.40V     choke off, throttle opened slightly, ±1000rpm
14:26h   6.56V     choke off, throttle opened further, ±2500rpm
This said, there will indeed be a lot of air going through the channel with the bypass screw as well.
14Back to top Go down   Replace K100 AFM by a MAF Empty Re: Replace K100 AFM by a MAF Thu Dec 29, 2022 10:11 am
jcd06
jcd06
A couple of weeks ago I had the pleasure to exchange emails with one of the SplitSec staff members.
I don't often experience such willingness from a high-tech company to help and think along.
I am grateful for the help and the useful input provided with their comments.
These are my findings, based on the SplitSec comments and my tests with the ECU (0 280 000 313) on the table.
Due to the specific way the AFM pot and the IAT resistor are wired, the ECU’s AFM input pin 7 gets information from the air flow meter as well as from the IAT temperature sensor.
On top of this, while the ECU itself compensates the injector pulse width for battery voltage variations, the combined IAT-AFM circuit is also subject to the battery voltage variations and does influence the injector pulse width as well.
Because the ECU expects these combined influences on pins 7 and 8, it is not a workable solution to apply only a converted signal from a MAF to the ECU’s AFM pin 7 input.
Unfortunately this means the voltage converter approach is not convenient as it would require multiple converters and combined lookup tables.
So at least for the time being I’ll leave this path.
An aftermarket ECU would most probably be an easier solution I think.
It would greatly simplify the implementation if the ignition part of the aftermarket ECU would be left unused and the original K’s ignition system remained.
The existing wiring harness to the ECU could then be used without modification. Conditions are that engine temperature sensor, injectors and trigger pulse coming from the K ignition module are compatible with this new ECU.
I won’t go for the other ECU as this was not my intention.
This said I’m always open for suggestions or thoughts regarding the K100 fuel injection in general.
