1Back to top Go down   larger badge on rear seat cowl  Empty larger badge on rear seat cowl Sat Nov 26, 2022 11:12 am
firstle
firstle
just noticed the BMW badge on the rear seat cowl is quite large ? when did they do this , i have two k100s one is a ex blood bike and has the larger badge .
2Back to top Go down   larger badge on rear seat cowl  Empty Re: larger badge on rear seat cowl Sat Nov 26, 2022 8:14 pm
Probably an aftermarket replacement. The badge on the lunch box should be the same size as the ones on the tank.
3Back to top Go down   larger badge on rear seat cowl  Empty Re: larger badge on rear seat cowl Sat Nov 26, 2022 10:27 pm
Dai wrote:Probably an aftermarket replacement. The badge on the lunch box should be the same size as the ones on the tank.
The tail cowl roundel is 60mm. The tank roundels are 70mm.
4Back to top Go down   larger badge on rear seat cowl  Empty larger badge on rear seat cowl Sun Nov 27, 2022 3:48 am
firstle
firstle
"Probably an aftermarket replacement" . maybe , this one is 81mm diamiter
5Back to top Go down   larger badge on rear seat cowl  Empty Rear cowl badge Sun Nov 27, 2022 6:21 am
daveyson
daveyson
The previous owner possibly did what I did. On mine the cowl is covered by the top box, but there was a badge on the mudflap. It was ratty, I saw a good one at the car junk yard so replaced it, it was a bit bigger.
 ~120,000 km
