1Back to top Go down   fuel tank cap key  Empty fuel tank cap key Mon Nov 14, 2022 3:36 am
firstle
firstle
is there marked on the fuel cap any id for the key ? the cap assembly is off (very luck i know) and i would like to get a key cut from a blank , is there any way . thanks
2Back to top Go down   fuel tank cap key  Empty Re: fuel tank cap key Mon Nov 14, 2022 4:15 am
firstle wrote:is there marked on the fuel cap any id for the key ? the cap assembly is off (very luck i know) and i would like to get a key cut from a blank , is there any way . thanks
If the gas cap is off of the tank then you can easily rekey it to work with any key (like the ignition key for example):
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/rekey/rekey.htm
3Back to top Go down   fuel tank cap key  Empty Re: fuel tank cap key Mon Nov 14, 2022 8:57 am
Use your ignition key and rekey the cap to suit it. No need to buy any key and you just need a small file to do it. I did one recently after buy a repalcement cap.
4Back to top Go down   fuel tank cap key  Empty Re: fuel tank cap key Mon Nov 14, 2022 9:11 am
+1 0n Olaf's suggestion.  It only takes a file and an hour, and then, whenever you stop for fuel you just need to grab the key that is in the ignition.
5Back to top Go down   fuel tank cap key  Empty thanks Mon Nov 14, 2022 9:17 am
firstle
firstle
thanks  Very Happy
6Back to top Go down   fuel tank cap key  Empty Re: fuel tank cap key Thu Nov 24, 2022 12:38 am
Well worth reading and keeping a copy for reference of Duck’s instructions about rekeying the K bike locks.
An example of the convenience is when I had a K75 and a K1100 and two different sets of panniers - I filed the pannier locks on both sets of panniers to accept the ignition key from either K bike, thus never needed to carry an extra key for either bike regardless of which pannier set I chose to use.
7Back to top Go down   fuel tank cap key  Empty Re: fuel tank cap key Thu Nov 24, 2022 12:09 pm
With five bricks having gone through my garage along with at least three sets of city cases/luggage I have accumulated a rather large collection of keys the management of which is a near full time job.  I have become fairly adept at rekeying luggage to work with multiple keys.
