1 fuel tank cap key Mon Nov 14, 2022 3:36 am
firstle
is there marked on the fuel cap any id for the key ? the cap assembly is off (very luck i know) and i would like to get a key cut from a blank , is there any way . thanks
firstle wrote:is there marked on the fuel cap any id for the key ? the cap assembly is off (very luck i know) and i would like to get a key cut from a blank , is there any way . thanks
Use your ignition key and rekey the cap to suit it. No need to buy any key and you just need a small file to do it. I did one recently after buy a repalcement cap.firstle wrote:is there marked on the fuel cap any id for the key ? the cap assembly is off (very luck i know) and i would like to get a key cut from a blank , is there any way . thanks
K100-forum.com » Technical, repair and troubleshooting » Frame, fairing and wheels » fuel tank cap key
Similar topics
