1 Clutch Doesn't Disengage Wed Oct 05, 2022 12:57 am
dnkn
I'm reassembling a 1985 K100RS that came to me in boxes. The drivetrain was substantially intact, but the clutch cable had been removed so the swing arm was just hanging and the boot between the swing arm and the push rod was torn. I replace the boot, reinstalled the cable, and adjusted per manual spec. But actuating the clutch lever doesn't seem to engage the clutch at all. Just to test, I ran the adjustment screw on the back of the arm all the way in to maximize the throw on the push rod. Still no engagement of the clutch. What are possible causes?
Thanks in advance for your help.
