1Back to top Go down   cooling fan running constantly Empty cooling fan running constantly Tue Aug 09, 2022 12:46 pm
leomassaro
leomassaro
hallo i've a problem.
i have bmw k 100 rs 4v 1991
when i start the bike start fan too and don't stop (only fo a moment random).
i've changed the sensor (new sensor).
i checked wiring and fan relè.
nothing.
have you solutions!
thanks.
2Back to top Go down   cooling fan running constantly Empty Re: cooling fan running constantly Tue Aug 09, 2022 3:52 pm
What methods did you use to check the wiring and fan relay, Leo?
3Back to top Go down   cooling fan running constantly Empty Re: cooling fan running constantly Tue Aug 09, 2022 5:25 pm
leomassaro
leomassaro
Laitch wrote:What methods did you use to check the wiring and fan relay, Leo?
i checked the sensor with how water.
i checked wiring with multimeter for contacs
i checked relay in this method: with bateery 12v i put + on 86 pin and - on 87 pin and i see the click. if relay did the click it' ok.
on my bike this is all ok and i have the same problem with fan.
i want check others relay and the temperature sensor.
4Back to top Go down   cooling fan running constantly Empty Re: cooling fan running constantly Tue Aug 09, 2022 6:15 pm
Did you get a 2v or 4 v temperature sensor? Look the same but they are not and not interchangeable.
5Back to top Go down   cooling fan running constantly Empty Re: cooling fan running constantly Wed Aug 10, 2022 3:14 pm
leomassaro
leomassaro
92KK 84WW Olaf wrote:Did you get a 2v or 4 v temperature sensor? Look the same but they are not and not interchangeable.
thanks but i purchased new sensor on bmw dealer with code.
leomassaro
leomassaro
hallo i've purchased ah other used motronic. i put it on my k 100 rs 16v but the fan running constantly.
some ideas?
thanks
7Back to top Go down   cooling fan running constantly Empty Re: cooling fan running constantly Tue Sep 27, 2022 10:28 am
Try swapping the fan relay with one of the other little black relays, like the horn relay. All 5 of those little black relays are the same.
cooling fan running constantly Relayb3
The fan relay is triggered when the Motronic sends a ground signal via the blue/yellow wire. See if the blue/yellow wire is grounded when the Motronic is unplugged. It shouldn't be. If it is then the blue/yellow wire has shorted to ground somewhere. Not likely but possible.
8Back to top Go down   cooling fan running constantly Empty grazie Tue Sep 27, 2022 10:38 am
leomassaro
leomassaro
siete fonte inesauribile di idee.
grazie
9Back to top Go down   cooling fan running constantly Empty Re: cooling fan running constantly Tue Sep 27, 2022 1:11 pm
recomu
recomu
ciao Leo, sono un tuo concittadino ed ho avuto gli stessi problemi. Sostituito la centralina tutto è tornato alla normalità. Ci si sente ...
10Back to top Go down   cooling fan running constantly Empty grazie concittadino. Tue Sep 27, 2022 3:59 pm
leomassaro
leomassaro
ciao,
ho appena finito di fare tutti i controlli e sono arrivato alla conclusione che non può essere altro che la centralina.
il dubbio mi era sorto poichè ho già acquistato altra centralina ma il problema è rimasto per cui anche grazie alla tua precisazione sono giunto alla conclusione che con la mia solita fortuna ho acquistato una centralina difettosa.
grazie ancora e a buon rendere per quel che posso.
Leonardo
