1 Charge Light on Constantly Mon Sep 14, 2015 12:45 pm
veets
The Red Charge light on my K100RT stays on constantly but the alternator is generating a charge (~13.5 volts at 2000 rpm). I have driven over 600 miles with the light on but would like to find the source if possible. The problem started when I was soaked on my bike and started experiencing some weird electrical issues. The charge light came on and every other gear (2nd & 4th) turned on the "neutral" light. The only numbers that showed up on the display was 1 & 0. After drying out the bike overnight, the "neutral light issue went away" but not the charge light.
I have looked through the past forums but have not found this exact problem. I have tried cleaning the ground connection and the alternator brushes.
Can someone point me to a past discussion or in the right direction?
Thanks,
Veets
Thanks,
Veets
