51 Re: K100 with high fuel consumption Sat Sep 24, 2022 5:29 pm
They need to transmit sufficient energy for efficient combustion of fuel.
Go to page : 1, 2
Laitch wrote:Those spark plugs don't smell of fuel and smoke is not emitted from the exhaust pipe during operation?
Laitch wrote:You seem to have located the site of the problem—cylinders #1 and #2. You indicate their cylinders' compression is within allowable variance with #3 and #4 and all cylinders are within the Good compression range. You indicate their coil pack resistance numbers are within specifications found here and agree with the #3/#4 pack numbers. You don't know the resistance of the #1 and #2 plug wires as compared with #3 and #4 wires. Are the plug wire terminals within the #1/#2 coil pack clean?
You also don't know what is creating oil deposits and fouling the plugs so they couldn't fire efficiently. Usually oil leaking into the combustion chamber caused by worn valve seals will emit some smoke with the exhaust while it is fouling the plugs ad increased oil consumption will be likely., but you indicate neither is happening. Are you certain the sludge on the plugs is from oil and not soot mixed with coolant or fuel? Is the coolant level stable in the coolant reservoir during all this?
If the plugs aren't firing, there will be no smoke but there will be a strong smell of fuel somewhere and a distinct loss of engine power, yet you indicate power is acceptable. If you rode this moto before doing the latest work, is there less power now? What is your ground speed at 5000rpm in fifth gear?
Believe it or not, you are getting close to resolving this.
1989 K100RT VIN 0097367 (naked) 1996 K1100RS VIN 0451808 | Fuel: 95 Octane Engine Oil: Nulon Full Synthetic 15W50 Gear Box Oil: Nulon Synthetic 75W90 |
Laitch wrote:Replace the fouled spark plugs, ride out again, compare your rides and also determine if the plugs are fouling quickly or are resisting fouling.
Holister wrote:If you have fouled plugs on #1 and #2 which fire off different coils then the problem will be down stream. If your temp sensor or maf were reading incorrectly then all cylinders would be affected.
Check your HT leads for correct resistance and even your spark plugs (they should be <0.3Ω). As they develop resistance the spark degrades.
Have you checked the coil resistance on those injectors? Should be 16.2Ω
Another possibility to consider is that you have #1 and #2 leads swapped around. That would certainly give you abnormally high fuel consumption and fouled plugs but I think you'd probably notice the decrease in power. Just a thought.
Verify that the front coil has the wires from spark plugs #1 and #4 and the rear coil has the wires from plugs #2 and #3. Replace the blackened spark plugs #1 and #2 with clean spark plugs of the correct type and test the moto. Fifth gear speed at 5000rpm might be illegal; record second, third and, maybe, fourth gear speeds.ouafnico wrote:The swapp you guess for . . . the spark plugs wires?
ouafnico wrote:It's good I have the good spark plugs wires at good places
5000rpm at 5th might be high indeed, I may able to check only some gears
ouafnico wrote:I checked my old spark plugs, but they are all black, so I can't use them to compare.
Globally the motor seems fine, . . . and I can drive at 50 km/h at 5th without any issue
Laitch wrote:That's interesting, isn't it? Replacement is the next step. Verify the electrode gap before installing the replacements and be certain that the spark plugs are tightened down sufficiently for successful heat transfer.
The 900 looks fun.
Here is the crux of the matter. Before you remodeled it, your LT Brick was manufactured as a touring machine designed to thrive on long distance travel at high speeds. It isn't surprising that your Brick is now drinking more after chugging around town. It is probably depressed because it doesn't enjoy being treated like a Bichon Frise with a short haircut. Although a periodic Italian tuneup might help, it won't respond well to long periods of idleness while the XSR gets the action.
Maybe you should trade it for a Gas Gas or a Tuk Tuk, as soon as it is running well.
Laitch wrote:It could be that you should change the color of one of the front brake calipers to white and the rear one to blue— or maybe the reverse —to determine if doing that improves fuel economy.
92KK 84WW Olaf wrote:Have you accidentally reversed the injector leads for cylinders 3 and 4?
Also, NGK plugs need bobbins, to go on the threaded part and the bobbins do not come with the plugs when you buy them.
No. Then your brake callipers will arrive at your destination before the rest of the bike does. Bad social form.ouafnico wrote:I made them red to go faster, like Ferrari's. You think it will work?
Point-Seven-five wrote:If your observations are correct, the engine appears to be operating correctly.
According to your original post, the air/fuel ratio your engine is running on is about 7:1, the lowest air fuel ratio a gasoline engine will run on is approximately 9:1. The amount of fuel you claim to be using is not possible in a running engine, and if indeed you could make it run, the engine would be having major problems with idle, acceleration, fouled spark plugs and large amounts of unburnt fuel in the exhaust.
I would suggest that you use the bike as normal and keep an accurate record of the actual distance traveled and the amount of fuel you use and recalculate the usage.
Rather than use the odometer, I would take a round trip over a known distance of at least 100km total and check the fuel used. You should have a number around 5-5.5 liters/100 km at normal speeds. At constant speeds above 140km/hr usage may rise to as high as 6.5 liters/100km.
Bikesmith wrote:Point-Seven-five wrote:If your observations are correct, the engine appears to be operating correctly.
This is the key right here. If Ouafnico's mixture was that far off, or if he wasn't getting ignition on some cylinders (eg swapped plug leads), the bike would be running terribly. He has repeatedly said the engine is running great. Yeah, his plugs are fouling a bit but he's saying it's running smoothly, not smoking, no gas smell. Though it might not be perfect, this is a bike that's at least running pretty well.
I totally agree with point-seven-five. Test the mileage with a measured distance ride rather than the odometer.
One other thing that comes to mind is that, since you're trying to track down an issue, you're likely spending a lot of time scratching your head while staring at an idling bike. It won't burn a ton of gas while idling, but it will burn some. Once, during a road trip, I was stopped for about half an hour for a construction delay with my bike idling the whole time. I keep track of my mileage with a phone app and at the next gas stop I was shocked at how bad my consumption had been for that stretch until I remembered the half hour stop. It makes a difference.
Also, in your response to my last suggestion about a slipping clutch you said the clutch was new, adjusted, and "seemed to be working fine". Did you try the test that Laitch suggested? K-bikes definitely have enough power to mask a problem like a slipping clutch. It could seem fine but still have issues.
Finally, check to make sure you aren't missing some silly, tiny error in your experimentation. All of this headache could be a math error (Not calling you bad at math, everyone makes small errors sometimes). A friend with a K75 was confused about fluctuating fuel consumption until I noticed that he sometimes uses the center stand while filling his bike and sometimes the side stand. Threw all his calculations way off. Are you 100% sure that your odometer is giving you kilometers, not miles? Bottom line is recheck all of your assumptions.
Go to page : 1, 2
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » K100 with high fuel consumption
Similar topics
