snooktarpon
snooktarpon
Hello Everyone,
I just joined the forum. I have a 1985 K100RS that I've owned since 1991. Unfortunately, my bike sat dormant for the past 12 years. I got it started yesterday just by replacing the battery and adding fresh gas. There was old gas in the tank so I was expecting the fuel pump to be frozen and my injectors to be clogged. Not the case. The motorcycle gods were on my side.
So I'm now on the the path of getting it back on the road. As you can expect after sitting for 12 years, it needs some TLC with all new fluids, filters, potential hoses, splines lubed, cables lubed, etc.
In addition, I now have the gear position switch issue so I'll be investigating that too (when I do my spline lube).
Sincerely,
Jim
Welcome!  Sounds like you dodged a big bullet with the old fuel.  The gear position switch should not be that much of a problem.  Several of us here have had good luck refurbishing them.  I have done two of them myself.
After such a long sleep, replace all the fuel hoses, outside and inside the tank.
It would be a miracle if the crank gasket will not start to leak on the clutch during the first miles...
You can avoid to pay for a brand new clutch disc by changing the gasket before it's contaminated by the engine oil (and the gearbox gaskets by the same time).
I've been restoring BMWs for many years, if they stayed unused for more than 3 years, this leak is systematic soon after they run again.
That fills our fairest day.
fishboy316
fishboy316
Hello! I am also running an85 K100rs. I love it!
Welcome
Welcome Jim Smile
New Member in Indiana - Just Resurrected my 1985 K100RS After Sitting for 12 Years Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
New Member in Indiana - Just Resurrected my 1985 K100RS After Sitting for 12 Years 177912
jbt wrote:After such a long sleep, replace all the fuel hoses, outside and inside the tank.
I've brought many Ks back to life after long slumbers and never had any of them foul the clutch. I have bought a couple that already had a dried out clutch nut O-ring though.
Bernie_K100
Bernie_K100
Hi Jim,
New Member in Indiana - Just Resurrected my 1985 K100RS After Sitting for 12 Years 177912 to this forum!
Bernie
bad boy
bad boy
hi Jim
New Member in Indiana - Just Resurrected my 1985 K100RS After Sitting for 12 Years 177912 here
and enjoy!
Cheerz, David
New Member in Indiana - Just Resurrected my 1985 K100RS After Sitting for 12 Years 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
