Thank you for the replies, The steering head bearings are ok,I checked them this week, they were replaced and adjusted when I rebuilt the bike 5000 miles ago. I think the problem is associated with the front axle and the spacing between lower yoke ends and the wheel. The wheel will run free until the pinch bolts and the axle end bolts are tightened and then there is a lot of drag on the wheel. I do not know if your setup, in regards, to the wheel spacing is the same as mine, 1985 K100RS but I had to install 8, 3 mm washers on the right side, looking at the bike from the front, just to get the brake strut in the proper location. I cannot ride the rig the way it is as the front end wobbles and shakes as soon as I start moving and gets worse as the speed builds to the point where it is completely uncontrollable. I have heard from Wasp once and he is surprised, I will give him another week to respond , I have sent him photos of the install and dimensions. If I do not hear from him by next week I will remove the assembly and restore the OEM front end and consign the unit to the bin, chalking it up as an expensive two year wait for something that does not work. Thanks again for your input, it is much appreciated. At 74 my riding time is finite, no time to waste on diagnosing a problem that should not be, I would rather be riding. Thanks again Craig
