1Back to top Go down   K75 & leading links Empty K75 & leading links Thu Apr 12, 2018 1:50 am
Rockman
I have a 1992 K75RT and a set of DMC leading links for a K100. I also have a set of K100 triple clamps. So the question is, do the K100 triple clamps fit the K75 and if so is there any reason I cant put the leading links on the K75? Alternatively, will the leading links fit the existing K75 clamps? This is for a possible sidecar project down the track a bit.
2Back to top Go down   K75 & leading links Empty Re: K75 & leading links Thu Apr 12, 2018 3:43 am
The K100 clamps will fit the K75 just fine.
The fork diameter can be a bit different but so long as you use K100 clamps with K100 forks all will be OK.
3Back to top Go down   K75 & leading links Empty Re: K75 & leading links Thu Apr 12, 2018 7:11 pm
Rockman
Thanks Rick. I thought they would but just needed to check. The K75/sidecar project is now on the list for the future Very Happy
