1Back to top Go down   K1100LT sidecar Empty K1100LT sidecar Sun Nov 14, 2021 3:52 am
Rockman
I've just purchased this! Its a non-runner but it looks like a well sorted outfit and the price was right. The plan is to work through the likely reasons it wont go until I find the problem. The description from the seller is that it got increasingly hard to start over several months, then wouldnt go at all. Any suggestions?
K1100LT sidecar K1100_10
2Back to top Go down   K1100LT sidecar Empty Re: K1100LT sidecar Sun Nov 14, 2021 5:10 am
I would start with the fuel system and injector clean with particular attention to the filter.
3Back to top Go down   K1100LT sidecar Empty Re: K1100LT sidecar Mon Nov 15, 2021 5:44 am
Rockman
RicK G wrote:I would start with the fuel system and injector clean with particular attention to the filter.
Yep,
My plan was to check there is a spark then look at the fuel system. The possibility of a hose split or blown off inside the tank also occurred to me.
4Back to top Go down   K1100LT sidecar Empty Re: K1100LT sidecar Tue Apr 19, 2022 7:19 am
Rockman
Just an update on this project. I've now done about 2500 km without any problems including 1500 last week to attend the Scrapheap Adv Ride in Gulargambone. The original route was varied a bit because of a couple of flooded roads. Fuel consumption averaged 15 km/litre and used no oil. I'm happy with that.
Jobs left to do are to sort out the front mudguard so that the wheel doesnt hit it on full compression, fix the odometer gears and check that the fan works or maybe fit an override switch.
K1100LT sidecar 20220414
Met up with the rest of the crew from Inverell in Moree.
K1100LT sidecar 20220413
SCRAPHEAP 2021 (April 2022)MAP
LEGLitresKmKm/lMPGNotes
Inverell - Moree8.6014516.8647.84Tail wind, 90-100 kmh
Moree - Goondiwindi8.5812714.8042.00Part head wind, 90-100 kmh
Goondiwindi - St George13.7020815.1843.08Little wind, 90-100 kmh
St George - Mungindi8.7812814.5841.37Side wind, 90-100 kmh
Mungindi - Moree8.6812113.9439.56Head - Side Wind 90-110 kmh
Moree - Collarenabri8.7814216.1745.8998 Octane 90 - 110 kmh
Collarenabri - Coonamble12.0019015.8344.93Little wind, 90-110 kmh
Coonamble - Gilgandra7.1810013.9339.52Little wind, 100 - 130 kmh
Gilgandra - Narrabri14.9820813.8939.40Little wind, 100 - 130 kmh
Narrabri - Inverell11.5517314.9842.50Little wind, 100 - 120 kmh
Totals & Averages102.83154215.0042.55
Best16.86
Worst13.89
5Back to top Go down   K1100LT sidecar Empty Re: K1100LT sidecar Tue Apr 19, 2022 8:54 am
Glad to hear all is going well with it.
Can't complain about about 42mpg. Wish the Triumph would get something like that! I reckon it averages about 12km l ( even less when you get further west and start sitting on 120 and above. )
6Back to top Go down   K1100LT sidecar Empty Re: K1100LT sidecar Tue Apr 19, 2022 12:56 pm
Looks like it's all sorted Phil it sure was a bargain for what it is. Now ya comin to the cane toad?
7Back to top Go down   K1100LT sidecar Empty Re: K1100LT sidecar Wed Apr 20, 2022 12:23 am
Rockman
RicK G wrote:Looks like it's all sorted Phil it sure was a bargain for what it is. Now ya comin to the cane toad?
Cane toad is out unfortunately - cant get away.
