1Back to top Go down   Handlebar absorbing clamp nuts Empty Handlebar absorbing clamp nuts Sun Aug 07, 2022 10:59 pm
bmwk100rs
bmwk100rs
Do the handlebar absorbing clamp nuts require torque? Otherwise, how much do you tight them?
Handlebar absorbing clamp nuts Img_3010
Handlebar absorbing clamp nuts Screen14
2Back to top Go down   Handlebar absorbing clamp nuts Empty Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 3:42 pm
bad boy
bad boy
Cheerz, David
Handlebar absorbing clamp nuts 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
3Back to top Go down   Handlebar absorbing clamp nuts Empty Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 3:43 pm
bad boy
bad boy
and this
https://i.servimg.com/u/f88/20/35/75/82/standa11.jpg
I do hope it is of any help to you
Cheerz, David
4Back to top Go down   Handlebar absorbing clamp nuts Empty Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 3:55 pm
bad boy
bad boy
I've just been told by a most reliable source:
16 Nm +/- 2
Cheerz, David
5Back to top Go down   Handlebar absorbing clamp nuts Empty Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 6:47 pm
bmwk100rs
bmwk100rs
bad boy wrote:I've just been told by a most reliable source:
16 Nm +/- 2
Thank you!
6Back to top Go down   Handlebar absorbing clamp nuts Empty Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 7:01 pm
RS Rider
RS Rider
Thanks. I'll be jotting this value down in the appropriate section of my Clymer manual.
7Back to top Go down   Handlebar absorbing clamp nuts Empty Re: Handlebar absorbing clamp nuts Wed Aug 10, 2022 3:10 am
bmwk100rs wrote:Do the handlebar absorbing clamp nuts require torque? Otherwise, how much do you tight them?
If you're trying to stiffen handlebar response, consider this guidance from duck.
8Back to top Go down   Handlebar absorbing clamp nuts Empty Re: Handlebar absorbing clamp nuts Wed Aug 10, 2022 3:22 am
bmwk100rs
bmwk100rs
Yes, I added those thrust washers. I was just looking for the torque to apply to the absorbing clamp nuts.
