2 Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 7:42 pm
bad boy
I have found this:
https://i.servimg.com/u/f88/20/35/75/82/fork_t10.jpg
Cheerz, David
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
3 Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 7:43 pm
bad boy
Cheerz, David
4 Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 7:55 pm
bad boy
I've just been told by a most reliable source:
16 Nm +/- 2
16 Nm +/- 2
Cheerz, David
5 Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 10:47 pm
bmwk100rs
bad boy wrote:I've just been told by a most reliable source:
16 Nm +/- 2
Thank you!
6 Re: Handlebar absorbing clamp nuts Tue Aug 09, 2022 11:01 pm
RS Rider
Thanks. I'll be jotting this value down in the appropriate section of my Clymer manual.
7 Re: Handlebar absorbing clamp nuts Wed Aug 10, 2022 7:10 am
If you're trying to stiffen handlebar response, consider this guidance from duck.bmwk100rs wrote:Do the handlebar absorbing clamp nuts require torque? Otherwise, how much do you tight them?
8 Re: Handlebar absorbing clamp nuts Wed Aug 10, 2022 7:22 am
bmwk100rs
Laitch wrote:If you're trying to stiffen handlebar response, consider this guidance from duck.bmwk100rs wrote:Do the handlebar absorbing clamp nuts require torque? Otherwise, how much do you tight them?
Yes, I added those thrust washers. I was just looking for the torque to apply to the absorbing clamp nuts.
K100-forum.com » Technical, repair and troubleshooting » Frame, fairing and wheels » Handlebar absorbing clamp nuts
Similar topics
