1Back to top Go down   K100/K1100 exhaust swap Empty K100/K1100 exhaust swap Thu Jan 13, 2011 6:15 pm
Comberjohn
Comberjohn
Has anyone fitted a K1100 exhaust system on to a K100? If so, any problems?
2Back to top Go down   K100/K1100 exhaust swap Empty Re: K100/K1100 exhaust swap Tue May 31, 2011 12:40 am
walker
Sorry to answer so late. Probably already have your answer.
K1100 exhaust bolted right on to my 91 K100RS. I had to find a plug for the oxygen sensor hole though. 20 mm I think.
3Back to top Go down   K100/K1100 exhaust swap Empty Re: K100/K1100 exhaust swap Tue May 31, 2011 2:18 am
Did the back mount of the K100 have to be used or the K1100.
4Back to top Go down   K100/K1100 exhaust swap Empty Re: K100/K1100 exhaust swap Tue Jun 07, 2011 8:57 pm
walker
It mounted directly to the bracket which hold both pegs, just like the original. The mount on the silencer can is attached behind passenger peg. Probably not hard to make a modified mount if not using the original peg brackets
