1 Please help Sun Jan 09, 2011 6:28 pm
87m6chris
90/K75s
I'm replacing the timing chain components at the moment, with the front most piston, #3 on TDC the valves are closed. Everything as it should be except the timing marks on the cam sprockets, crank sprocket and crank keyway notch are no where near where they are suppose to be according to the the Haynes manual.
Illustration 23.3 in the Engine section page 2.21 shows the crank keyway notch at 6 oclock and the counter weights at 12 oclock, on my crank with the counter weights at 12 the keyway is at 10 oclock.
Are all the timming marks just for K100's?
