1Back to top Go down   removing the oil filter Empty removing the oil filter Tue Jan 11, 2011 10:01 pm
I just saw this one on a French forum and have to share it with you.
Sometimes, your oil filter is so tight that even the BMW oil filter wrench will spin on the filter.
I experienced this before and it was a BIG job to remove it. By the way, always put some oil on the oil filter gasket and never tight the filter by more than 1/4 turn
Somebody had a great idea, and it worked where any other solution failed.
Drill 2 (or 4) holes on the wrench, and screw it on the filter. removing the oil filter 112350
Here are some pics:
removing the oil filter Filtre10
removing the oil filter Filtre11
removing the oil filter Frog15removing the oil filter Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
2Back to top Go down   removing the oil filter Empty Re: removing the oil filter Tue Jan 11, 2011 11:07 pm
Ajays has mentioned this as an option he uses in a previous post too. Sometimes just whacking a great big honking screwdriver up into the filter at an angle will take the bugger off! Carefully, though, as you risk buggering the threads. It's a fine line we walk when tightening an oil filter. You don't want it to un-spin, but you don't want to have to wrestle to remove it either. I know of a mate who didn't tighten his enough and it came off while riding down the road. He didn't know it of course until he stopped at a light and heard an unusual mechanical cacophony and the oil pressure light gave him a mini light show! Catastrophic failure.
Thanks for the reminder, Crazy Frog!
3Back to top Go down   removing the oil filter Empty Re: removing the oil filter Wed Jan 12, 2011 5:47 am
Ajays solution is a bit different as he punctures the filter to insert the 2 bolts.
The solution that I mentioned uses metal screws to attach the wrench on the filter. The wrench cannot pop out when you try to turn it.
removing the oil filter Fit%20Adpt
4Back to top Go down   removing the oil filter Empty Re: removing the oil filter Wed Jan 12, 2011 9:46 am
There's more than one way to pull a tooth. Both look like effective mechanical advantage to me.
