Number of posts : 7967
The casings should have 31/11 or 32/11 on the outside. 31/11 is from early K100RS and 32/11 from early K100 and K100RS. Check the casings first and if you have one of each then as said you can count the teeth and that does it for you.
Curious as to why they were dismantled. I have a few spare final drives but have not disassembled them. You may [should] be able to reunite them by following the wear patterns.
If you are reassembling I should ptrobably put in a new big bearing. I had one give out at 80,000 miles [had it from 26,000 miles] and another at 100,000 miles [had it since 58,000 miles].
1971 Yamaha 125 YAS-1
