51 Re: [solved]k75 Strange starting problem Sun Nov 21, 2021 8:14 pm
Go to page : 1, 2
Agree. Most meat thermometers are thermocouples rather than RTD (Resistance Temperature Detector) style sensors. RTD sensors are significantly more accurate and significantly more responsive than thermocouples. You'd be better off using a special purpose instaread kitchen thermometer like this.MartinW wrote:It's possible that depending on it's quality the meat thermometer could be slightly out. How does the temperature readings compare between the digital and the meat thermometer.
It would seem that you have remeasured the sensor correctly and are getting a correct value but I have to agree that the symptoms described does indicate a faulty temp sensor with infinite resistance at starting temperature. However, the temperature 'profile' obtained (post 44), even when measuring (incorrectly) across the sensor terminals, is inline with what you'd expect, it's just the values are double because the measurement is through both thermistors.costellon wrote:Duh! Well that was 4 hours of my life that i'll never get back - but now I know.
Edit: Currently reading 2500 @ 24*c - corresponds nicely with the graph of values.
1989 K100RT VIN 0097367 (naked) 1996 K1100RS VIN 0451808 | Fuel: 95 Octane Engine Oil: Nulon Full Synthetic 15W50 Gear Box Oil: Nulon Synthetic 75W90 |
Point-Seven-five wrote:It's possible that you have a problem with the check valve in the tank where the return line connects. These valves have had problems that result in high fuel pressure and over fueling when starting.
+192KK 84WW Olaf wrote:You have successfully tested most of the things that can cause issues but I am not sure if you have tested the temperature sensor at the plug end which would reveal if there is a break in the wiring, not unheard of.
I'm wondering if the last sentence in the quote above is a conclusion you have drawn, or a query. Both Bosch and BMW change parts' numbers occasionally. In a BMW parts fiche, the superseding part number is indicated. In the fiche, two ficu units have been listed. The reason for changing the number could be from a tweak to its manufacturing, or an inventory re-configuring. Either part will work—as Arlina indicated. BMW has a long history of installing mid-production remodeling that is interchangeable.costellon wrote:I grabbed a pic of the FICU (see below) and noticed that it has a different bosch number to the one on my last K75 .... are all the K75 FICU's interchangable ? I'm wondering why some have different part numbers ....... doesn't matter.
Go to page : 1, 2
K100-forum.com » Technical, repair and troubleshooting » Other K bricks (K75, K1100, K1) General discussion. » [solved]k75 Strange starting problem
Similar topics
