1Back to top Go down   Clutch Centering Alignment Tool Empty Clutch Centering Alignment Tool Wed Aug 18, 2021 10:42 pm
bmwk100rs
bmwk100rs
Can the clutch centering-alignment tool bind a little bit or does it have to rotate completely free as Chris Harris suggests?  Mine was rotating free until after I torqued the final two screws in the star sequence. Should I undo them and reposition it again?
https://youtu.be/RybnCX6PlIE?t=384
Clutch Centering Alignment Tool Img_0932
2Back to top Go down   Clutch Centering Alignment Tool Empty Re: Clutch Centering Alignment Tool Thu Aug 19, 2021 3:33 am
Has to turn free.
Unbolt, and try again.
Clutch Centering Alignment Tool Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   Clutch Centering Alignment Tool Empty Re: Clutch Centering Alignment Tool Thu Aug 19, 2021 5:53 pm
Your photo seems to indicate that you fastened only three screws, bmwk100rs. This time, gradually and sequentially fasten all six screws while checking centering tool rotation.
Clutch Centering Alignment Tool Img_0910
4Back to top Go down   Clutch Centering Alignment Tool Empty Re: Clutch Centering Alignment Tool Fri Aug 20, 2021 11:59 pm
bmwk100rs
bmwk100rs
Unbolted, readjusted, and re-torqued. It turns free now. Thank you, both!
Clutch Centering Alignment Tool Aligne10
