2 Re: Removing the Water/Oil Pump Front Cover Fri Aug 20, 2021 11:58 pm
Some of those covers can be difficult. Getting a bit more enthusiastic should be the answer. I had to use a fine knife blade to remove one a few years ago.
3 Re: Removing the Water/Oil Pump Front Cover Sat Aug 21, 2021 12:46 am
Don't use a pry bar, gently or otherwise. Mating surfaces could be damaged.
Rick G's fine-knife method would likely work, of course, but there's always the danger of self-inflicted slash injuries by the inexperienced, and then the cost of a new fine knife when the used one looks like a beaver has been chewing on it.
Judging from the appearance of the pump's inlet, the pump's cover seam could have barnacles growing along it. An alternative method might be heating the perimeter of the cover with a heat gun or hair dryer then squirting some Liquid Wrench along its seam with the engine block, taking an emotionally restorative break, then tapping the cover sideways multiple times—like the drum breaks in Surfin' Bird—around its perimeter with the rubber mallet—preferably a deadblow mallet. Don't imitate Thor, no matter how much you might worship him. Be patient. Be persistent.
4 Re: Removing the Water/Oil Pump Front Cover Sat Aug 21, 2021 2:06 am
To make it easier to understand, the old sealant has a good grip and that is what is holding it together. You will see this when it is apart.
Along the upper section you will see a lip which goes in towards the engine. If you push a blade screwdriver in there and work your way along you should be able to loosen the top edge which will break the seal. Then it is a matter of "peeling" off the cover. Looking from the front, in the top right corner you can lever the screwdriver against the engine bolt head.
Start gently and then tap the handle of the screwdriver with the palm of your hand till it "breaks". The longer the screwdriver, the easier it will be.
As the lip is not part of the sealing surface it does not matter if you damage it although I don't expect you will.
6 Re: Removing the Water/Oil Pump Front Cover Sat Aug 21, 2021 2:47 am
Yes, although yours appears to go forward whilst my K75's goes to the rear.
Is it possible the 100 and 75 are different?
8 Re: Removing the Water/Oil Pump Front Cover Sat Aug 21, 2021 3:33 am
My bad. School day, etc...
9 Re: Removing the Water/Oil Pump Front Cover Sun Aug 22, 2021 6:17 pm
bmwk100rs
TacKler wrote:If you push a blade screwdriver in the top right corner you can lever the screwdriver against the engine bolt head.
Thanks TacKler, that did it. For future reference, see below a picture showing where to place the screwdriver against the engine bolt. I was surprised that it put such a fight with so little of that red seal. Thanks again!
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Removing the Water/Oil Pump Front Cover
Similar topics
